jillybean 2 Posted November 14, 2019 Posted November 14, 2019 Using roku beta 3.0.193 (but also happens in release version) Server 4.3.0.20 I have 2 tv channels that have a lot of short duration shows of less than 30 minutes back to back throughout the day (mostly kids shows). It is not possible to arrow through each show in the timeline for these channels. The focus jumps ahead - generally about 2 hours ahead. This jump is not to the next 'normal length' show but just to whatever is about 2 hours further in the guide. @@ebr
ebr 16335 Posted November 14, 2019 Posted November 14, 2019 Hi. Can you show me a screen shot of this?
jillybean 2 Posted November 14, 2019 Author Posted November 14, 2019 Hi. Can you show me a screen shot of this? Channels 22 & 23 are the ones affected. First shot is Emby guide showing the initial focus on the current show. Second shot is guide after arrowing once to the right. I hadn't previously noticed the 'grey space' at the end of the row on each of these channels so I fired up Plex to be sure all the info was there - third shot is Plex guide with all the info. I get my guide from IceTV for both Emby and Plex.
ebr 16335 Posted November 14, 2019 Posted November 14, 2019 Yeah, the guide isn't anticipating that many short programs. We'll take a look. Thanks.
jillybean 2 Posted March 7, 2021 Author Posted March 7, 2021 Any movement on this? I typically view the guide and set recordings from there, but this is impossible to do for those 2 channels.
ebr 16335 Posted March 7, 2021 Posted March 7, 2021 Hi. Sorry, this seems to have fallen through the cracks. Thanks for reminding us.
speechles 2062 Posted March 8, 2021 Posted March 8, 2021 Reference: Issue #1068: [LiveTV Guide] Short program rows are unfocusable
ebr 16335 Posted March 11, 2021 Posted March 11, 2021 Hi. Can you please test this with the latest beta version of the app? Thanks.
jillybean 2 Posted March 11, 2021 Author Posted March 11, 2021 1 hour ago, ebr said: Hi. Can you please test this with the latest beta version of the app? Thanks. Updated and fixed. Am able to move through each show in the guide on all channels. Thank you.
Luke 42241 Posted March 12, 2021 Posted March 12, 2021 2 hours ago, jillybean said: Updated and fixed. Am able to move through each show in the guide on all channels. Thank you. Thanks for the feedback !
