Sammy 791 Posted November 14, 2019 Posted November 14, 2019 Every single recording I do goes through MCEBuddy within minutes of finishing recording. Thumbnail Extraction starts then too. Both are taxing on my CPU/GPU and I don't need any thumbnails or any metadata for that matter on these recordings as it will happen again on the processed recording. Is there a way to turn these things off for recordings only? Sent from my SM-G960U1 using Tapatalk
Solution Luke 42217 Posted November 14, 2019 Solution Posted November 14, 2019 Yes, explore the settings for the library that the recording belongs to. 2
Sammy 791 Posted November 14, 2019 Author Posted November 14, 2019 Ah ha! One of my recording libraries had Thumbnail Image Extraction toggled on. I turned it off and will monitor going forward. Sent from my SM-G960U1 using Tapatalk
