Happy2Play 9811 Posted November 13, 2019 Posted November 13, 2019 /*Dashboard Restart Notification Bell*/ #dashboardPage div.infoBanner.restartInfoBanner.flex.align-items-center i { color: red; -webkit-animation: flash linear 1s infinite; animation: flash linear 1s infinite; } @-webkit-keyframes flash { 0% { opacity: 1; } 50% { opacity: .1; } 100% { opacity: 1; } } @keyframes flash { 0% { opacity: 1; } 50% { opacity: .1; } 100% { opacity: 1; } } /*Scheduled Task Running*/ div.scheduledTaskPaperIconItem[data-status="Running"] i.listItemIcon.md-icon { background-color: red; -webkit-animation: flash linear 1s infinite; animation: flash linear 1s infinite; } 2
KickVanelli 5 Posted November 19, 2019 Posted November 19, 2019 Hi Happy2Play, I like it very much but it doesn't work for me. I see no difference (I'm running 4.3.0.23).
Happy2Play 9811 Posted November 19, 2019 Author Posted November 19, 2019 Hi Happy2Play, I like it very much but it doesn't work for me. I see no difference (I'm running 4.3.0.23). That is what I am running on. This usually means you have broken code somewhere.
Happy2Play 9811 Posted November 14, 2020 Author Posted November 14, 2020 (edited) Add Missing and Unaired indicators and color change on unaired Complete code if you only want this, you can drop the @-webkit-keyframes flash and @keyframes flash if you already have it. /*Missing and Unaired indicators*/ div.undefinedmissingIndicator {color: red;} div.undefinedunairedIndicator {color: orange;} div.unairedIndicator { background: orange; } div.missingIndicator, div.unairedIndicator { -webkit-animation: flash linear 1s infinite; animation: flash linear 1s infinite; } @-webkit-keyframes flash { 0% { opacity: 1; } 50% { opacity: .1; } 100% { opacity: 1; } } @keyframes flash { 0% { opacity: 1; } 50% { opacity: .1; } 100% { opacity: 1; } } Edited November 14, 2020 by Happy2Play
Meeko 35 Posted October 18, 2022 Posted October 18, 2022 How can i translate the Words "missing" and "Unaired" ?? is it possible in css?? best regards
Happy2Play 9811 Posted October 18, 2022 Author Posted October 18, 2022 1 hour ago, Soldize said: How can i translate the Words "missing" and "Unaired" ?? is it possible in css?? best regards You mean something like this? /*Chang Unaired text*/ div.undefinedunairedIndicator, div.unairedIndicator { text-indent: -9999px; line-height: 0; } div.undefinedunairedIndicator:after, div.unairedIndicator:after { content: "Future"; text-indent: 0; display: block; line-height: initial; } Same for div.undefinedmissingIndicator, div.missingIndicator.
