rwrisinger@gmail.com 0 Posted November 12, 2019 Posted November 12, 2019 Good Afternoon, I'm having an issue externally with very poor stream quality. So much so that people have just stopped using my server. I recently had to reload the OS on the my server and "rebuild" the Emby side (Folders\Users\Etc). I can stream to any device internally on my network, however externally now, for some reason, I get horrible pixelation. (Attached)It was working flawlessly before the SSD replacement and OS reload. So i can't figure out whats changed. Any help you can provide would be outstanding. Thanks!
Happy2Play 9806 Posted November 12, 2019 Posted November 12, 2019 Can you post the Server and ffmpeg logs.
rwrisinger@gmail.com 0 Posted November 12, 2019 Author Posted November 12, 2019 See Attached ffmpeg.txt embyserver.txt
ebr 16313 Posted November 12, 2019 Posted November 12, 2019 It is transcoding down to 1.3Mb/s. What is your connection speed both up from your server and down from where ever this is going?
rwrisinger@gmail.com 0 Posted November 12, 2019 Author Posted November 12, 2019 So its looking like my home internet of 400Mbps I'm paying for is getting throttle bottle necked some where
Jdiesel 1435 Posted November 12, 2019 Posted November 12, 2019 Clients are probably set on Auto quality
Luke 42217 Posted November 13, 2019 Posted November 13, 2019 Try increasing the in app quality setting and see if this helps.
