jhonata2050 0 Posted November 11, 2019 Posted November 11, 2019 Hello, I am trying to install emby on a debian machine, and it is not installed and says that some files could not be found or could not be executed, as shown in the image below.Can anyone help me with this problem
riothamus 53 Posted November 11, 2019 Posted November 11, 2019 (edited) From what it looks like, you are missing 'ldconfig' and the command/script 'start-stop-deamon' from your PATH environment variable. This is odd, since you are running the install command as the root user. As the root user, what do you get when you run: which ldconfig On Debian, it should be located at /usr/sbin/ldconfig (it's provided by the libc-bin package) Wait, my bad, you just ran the 'su' command by itself, that's why you don't have root's PATH. Instead, if you are going to switch to the root user, run: su -i or, better yet, just do this as a regular user: sudo dpkg -i emby-server-deb_4.2.1.0_amd64.deb Edited November 11, 2019 by riothamus
jhonata2050 0 Posted November 11, 2019 Author Posted November 11, 2019 (edited) Pelo que parece, você está perdendo 'ldconfig' e o comando / script 'start-stop-deamon' da sua variável de ambiente PATH. Isso é estranho, já que você está executando o comando install como o usuário root. Como usuário root, o que você obtém ao executar: qual ldconfig No Debian, ele deve estar localizado em / usr / sbin / ldconfig (é fornecido pelo pacote libc-bin) Espere, meu mal, você acabou de executar o comando 'su' por si só, é por isso que você não tem o PATH do root. Em vez disso, se você estiver indo para o usuário root, execute: su -i ou, melhor ainda, faça isso como um usuário comum: sudo dpkg -i emby-server-deb_4.2.1.0_amd64.deb OLÁ AMIGO, consegui instalar aqui, mas adicionar o usuário no modo raiz, pode adicionar o local onde encontrar o emby, por exemplo: sudo dpkg -i / home / logonet / transferencias / emby-server-deb_4.2.1.0_amd64.deb - eu embro - servidor - deb_4 . 2.1 . 0 _amd64 . deb após isso, consegui fazer a instalação, obrigado pelas dicas Edited November 11, 2019 by jhonata2050
riothamus 53 Posted November 11, 2019 Posted November 11, 2019 No problem, glad you got it sorted out!
