gngobin 0 Posted August 9, 2020 Posted August 9, 2020 Now I'm connected but the video bar starts to load then goes back and starts again video never starts
Luke 42210 Posted August 11, 2020 Posted August 11, 2020 On 8/9/2020 at 3:51 PM, gngobin said: Now I'm connected but the video bar starts to load then goes back and starts again video never starts @gngobin let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
gngobin 0 Posted August 14, 2020 Posted August 14, 2020 everything is up and sometimes it works other times it does not. I tryied pin did not work did manual could not connect I want to signup for life time but not if I can't get it to work.
Carlo 4561 Posted August 15, 2020 Posted August 15, 2020 Hi @gngobin is this something you would be able to show me if we did a remote support session via TeamViewer?
gngobin 0 Posted August 17, 2020 Posted August 17, 2020 Gettign error "We're unable to connect to the server right now. Please jensure it isw running and try again -56: Recv failure: Connection reset by peer
gngobin 0 Posted August 17, 2020 Posted August 17, 2020 I have set my ip to static 192.168.1.30 and I use that in the host file. login seems to work but the happen every time.
Carlo 4561 Posted August 17, 2020 Posted August 17, 2020 18 minutes ago, gngobin said: I have set my ip to static 192.168.1.30 and I use that in the host file. login seems to work but the happen every time. wait, what are you doing with the host file? That might cause you grief. You can't go using alias name as would be done via host files as Emby won't be using that. 17 minutes ago, gngobin said: I also turned on log tracking just in case Log tracking on the Server?
Luke 42210 Posted August 23, 2020 Posted August 23, 2020 @gngobin are you still having an issue with this?
