lalajee 2 Posted November 10, 2019 Posted November 10, 2019 Hi, I just download new version of emby but the system is not reading the nfo files for data it has overwitre with default. When I transfer the .nfo file from my backup it doesnt read it (even running the scan) but I i modify the file it scans and picks the information.
Happy2Play 9806 Posted November 10, 2019 Posted November 10, 2019 Why do you feel they are not being read? I have no issue deleting a item, and adding that item back from backup that contains all custom nfo metadata.
lalajee 2 Posted November 10, 2019 Author Posted November 10, 2019 Why do you feel they are not being read? I have no issue deleting a item, and adding that item back from backup that contains all custom nfo metadata. I have just add the movies path and run the scan but its not picking up any data from nfo files.
Happy2Play 9806 Posted November 10, 2019 Posted November 10, 2019 (edited) I have just add the movies path and run the scan but its not picking up any data from nfo files. Can you post the server log that corresponds with that action. Edited November 10, 2019 by Happy2Play
lalajee 2 Posted November 10, 2019 Author Posted November 10, 2019 (edited) How Can you post the server log that corresponds with that action. How do i get server logs Edited November 10, 2019 by lalajee
Happy2Play 9806 Posted November 10, 2019 Posted November 10, 2019 How How do i get server logs How to Report a Problem
Solution lalajee 2 Posted November 11, 2019 Author Solution Posted November 11, 2019 How to Report a Problem After change the scan from date added to when library is scan, its picking all of the nfo files with all of the data.
