Setup Guide for Live TV using ServerWMC
krustyreturns
So cool, thanks!  I assume you don't mind if I link to it.  I can think of a whole lot of stuff to add if you ever do a revision 2!
If you don't mind making an easy revision now, we are trying to get people to start using this link to our download page (I just put it in the mbs plugin I released yesterday):
http://bit.ly/ServerWMC
It helps us keep stats and will be used as we implement autoupdate.  Thanks again.
  • Like 1
Mediaputer
Absolutely. Thanks, I'll update the post as well.
  • Like 1
  • 8 months later...
Deleting this post, I found through installation how to connect the server piece to a remote WMC.
Edited by tornadotj
  • 1 year later...
nairnmonster
What if I already have Emby server installed on another machine, if I install it on an HTPC with the TV tuner. Would that mean the already setup Emby server would need removed?
