ckat90 5 Posted November 8, 2019 Posted November 8, 2019 Hello, my Amazon fire stick was working fine, when I went to connect this afternoon it would not connect. So I checked my computer, it was on. I checked the server on my phone, it opened no problem. Not sure what is going on all of a sudden.
ebr 16338 Posted November 8, 2019 Posted November 8, 2019 Hi. Exactly what happens when you try? How are you logging in?
ckat90 5 Posted November 8, 2019 Author Posted November 8, 2019 When I open the app it opened to the select server screen, which it had never done before. When I select the server it says server unavailable. I tried logging out of connect and logging back in still did not work. I tried adding manually as well.
ckat90 5 Posted November 8, 2019 Author Posted November 8, 2019 So weird, I removed the server and restarted the fire stick and then it worked.
