ertagon2 44 Posted November 8, 2019 Posted November 8, 2019 So I have some anime movies with dual audio and both audio tracks work fine when played locally on VLC but when played from the emby app one of the tracks (so far only English) would play with no sound.Any fixes ?
ebr 16313 Posted November 8, 2019 Posted November 8, 2019 Hi. Please provide specifics for the example. Thanks. How to Report a Problem
ertagon2 44 Posted November 8, 2019 Author Posted November 8, 2019 I have a .mkv anime movie with dual audio track English and Japanese. The Japanese track works fine but when I switch over the English track, there is nothing, it dead silent, the movie plays alright tho.It works fine when played from VLC from my PC.Stream Loghttps://pastebin.com/Tpci0PSP Server loghttps://pastebin.com/ZdVF0KAm
Luke 42217 Posted November 8, 2019 Posted November 8, 2019 Can you check the mkc container and see if the track has a large audio delay set? If yes then this is currently a known issue as we haven't added support for that when transcoding.
ertagon2 44 Posted November 8, 2019 Author Posted November 8, 2019 (edited) It's got 3.6s. Is that a lot ?I checked another one and it has 25s.Is there something I can do to fix it? Are you guys planning on fixing it since it's "known issue"? Edited November 9, 2019 by ertagon2
Luke 42217 Posted November 9, 2019 Posted November 9, 2019 Yes it's planned for the future. Immediate workaround would be to remux the file and remove the delays.
ertagon2 44 Posted November 9, 2019 Author Posted November 9, 2019 Yes it's planned for the future. Immediate workaround would be to remux the file and remove the delays. Okay thank you for your help. Do you have an opened GitHub issue about this? I can't find anything.
