yarez0 22 Posted November 7, 2019 Posted November 7, 2019 Hi Luke, I'm trying XIAOMI MIBOX S android tv box and the amby app is great (better than LG tv app and iOS I think) but I have a volume control issue. The mibox is connected through SPDIF to a sound bar, on all video apps on the box I can control the volume with the mibox controler but not on the emby app ! I tryied to look for an option but I can't find anything. also it seems like there is a sound issue : I noticed that the sound is a littlte bit bad, acute (aigue [FR] ?) are too high / saturated, low seems to be great (but it is maybe because of my sound bar) all parameters are by default andoid tv : xiaomi mibox s android tv app : 1.7.54g server : synology up to date sound bar : freebox player devialet is there a parameters that I missed ? I can't find the app logs thanks
ebr 16338 Posted November 7, 2019 Posted November 7, 2019 Hi. If the audio is bitstreaming, the volume has to be controlled by the outboard equipment. It sounds like that is probably what is happening. Can you provide the info from the "Stats for Nerds" screen during playback?
yarez0 22 Posted November 7, 2019 Author Posted November 7, 2019 infos lecture : lecteur : ExioPlayer mode d'affichage : 1080/60,00 méthode de lecture : Direct play type de flux : mkv infos flux : resolution video : 1920x1080 codec audio : H264 (direct) débit : 12,30 Mbps codec audio Dolby (direct) info du media d'origine : conteneur : mkv codec video : H264 debit video : 12,30 Mbps frame rate : 23,98 fps codec audio : Dolby debit audio : 448,00 Kbps canaux audio : 5.1
yarez0 22 Posted November 7, 2019 Author Posted November 7, 2019 another one : infos lecture : lecteur : ExoPlayer mode d'affichage : 1080/60,00 méthode de lecture : Direct stream type de flux : HLS infos flux : resolution video : 1920x1080 codec video : H264 (direct) codec audio : Dolby cannaux audio : 5.1 débit : 10,20 Mbps debit maximum : 80 Mb/s vitesse de transcodage : 708,00 fps motif du transcodage : audio non supporté etat du trasncodage : 36,78% info du media d'origine : conteneur : mkv codec video : H264 debit video : 10,01 Mbps frame rate : 23,98 fps codec audio : Dolby+ debit audio : <inconnu> canaux audio : and another one wich is controlled by the remote : audio with AAC stereo infos lecture : lecteur : ExoPlayer mode d'affichage : 1080/60,00 méthode de lecture : Direct play type de flux : mkv infos flux : resolution video : 1920x1080 codec audio : H264 (direct) débit : 8,03 Mbps codec audio : AAC (direct) info du media d'origine : conteneur : mkv codec video : H264 debit video : 8,03 Mbps frame rate : 23,98 fps codec audio : AAC debit audio : 448,00 Kbps canaux audio : stereo
Solution ebr 16338 Posted November 8, 2019 Solution Posted November 8, 2019 The two that are fixed volume are bitstreamed compressed audio. There is no volume control for that. 1
yarez0 22 Posted November 8, 2019 Author Posted November 8, 2019 Ok so this is a normal behavior. If I understand every files with DTS or Dolby sound cannot be controlled by the remote whereas stereo can
yarez0 22 Posted November 8, 2019 Author Posted November 8, 2019 to my knowledge : why bistream track cannot be managed by the remote ? I understand that AAC track is decoded by the client, so the volume control can be managed by the client because the audio track is managed by the emby app whereas bitstream strack are not managed at all by the client, the emby app just passthrough the track to the sound bar without any control. the client is not design to just control the track output volume, only for those managed by the app am I right ? If I am, I saw an option to "downstream audio" (if I remember well) if I want to control the volume for bitstream tracks I have to activate the option but in that case the client will transcode the Dolby/DTS/whatever tracks to PCM but I will lose the benefits of x.1 tracks right ?
Luke 42246 Posted November 8, 2019 Posted November 8, 2019 to my knowledge : why bistream track cannot be managed by the remote ? It can, if your remote can control the audio of your receiver. Does it do that? 1
ebr 16338 Posted November 8, 2019 Posted November 8, 2019 It can, if your remote can control the audio of your receiver. Does it do that? He doesn't have a receiver but the same would apply to the TV (which should be controlling sound for the sound bar). In short, you are much better off using the outboard audio equipment to control volume than the Android system. 1
yarez0 22 Posted November 8, 2019 Author Posted November 8, 2019 (edited) It can, if your remote can control the audio of your receiver. Does it do that? oh ok, but no the remote is bluetooth to the mibox, the mibox is connected through SPDIF to the sound bar and the sound bar has infrared remote. sound cannot be controlled by SPDIF or I have to find a universal remote that can control the mibox by bluetooth AND the sound bar by infrared. if the sound bar has HDMI port I can control it by CEC but this not my case He doesn't have a receiver but the same would apply to the TV (which should be controlling sound for the sound bar). In short, you are much better off using the outboard audio equipment to control volume than the Android system. yep, I just ask. I'm thinking of it because the sound bar has only 2.1 channel, I'm wondering if there a gain to keep it that way or not but yes I be used to have 2 remotes thank you guys Edited November 8, 2019 by yarez0
ebr 16338 Posted November 9, 2019 Posted November 9, 2019 yep, I just ask. I'm thinking of it because the sound bar has only 2.1 channel, I'm wondering if there a gain to keep it that way or not but yes I be used to have 2 remotes I would just set the app to downmix and then you can control everything. Unless this produces inferior sound, that should solve your problem. Thanks.
