Kubernetes with GPU acceleration
  • 1 month later...
On 26/08/2024 at 07:24, joncy92 said:
Hey dude I've been trying to get my GPU available to my emby which is running on k3s/rancher
Are you running single node k8s? If not how do you make the GPU available to each node for fail over?
Also is there anything specific you had to do with the node and k8s to make the GPU available to the deployment other than the environment variables?
Thanks
so anyone else looking at this it's not possible.
The GPU is only present on the VM it's attached to as a device. For failover with continued transcoding, you'd need to have another GPU attached to another machine.
With mine I've been trying to figure out to stop intel iGPU disabling when discrete graphics detected but can't find the option in Supermicro BIOS
Edited by joncy92
  • Thanks 1
