Deat69 2 Posted November 3, 2019 Posted November 3, 2019 So I don't know if this is a new thing because Emby Theatre doesn't tell you when it updates, but recently when watching older series that are in a 4:3 ratio I usually can use the fill Aspect Ratio to stretch to my screen size. It used to remember this so long as I didn't come out of the video and go back in, but now every episode I have to reset the aspect ratio. Windows 10 version 1903 Emby Theatre 3.0.10 Emby Server 4.2.1.0
Luke 42242 Posted November 3, 2019 Posted November 3, 2019 Hi, this isn't something we've ever specifically looked at, making it remember from one video to the next. It's possible for the future.
Guest asrequested Posted November 3, 2019 Posted November 3, 2019 You can probably put it in the mpv.conf, then it should function in perpetuity.
Deat69 2 Posted November 3, 2019 Author Posted November 3, 2019 It used to work which is why I wanted to point it out, thank you for the speedy response.
