jhoff80 94 Posted November 2, 2019 Posted November 2, 2019 (edited) I'm not sure if MediaInfo is used for movie length, or if it's pulled from the internet metadata. What I do know is that when you switch between versions of a movie, the length stays the same in Emby. Here, it shows 2:27 based on the theatrical version: But when I switch to the director's cut it still shows 2:27 even though this version is 2:50: I'd love if this updated based on the version of the movie I've got selected. Or, if you're using internet metadata in that spot, then maybe it'd instead make more sense to add actual length based on file down in the bottom Media Info sections. Just as a section under "Video" for each file. Edited November 2, 2019 by jhoff80 4
Luke 42246 Posted November 2, 2019 Posted November 2, 2019 Hi, yes it's possible to improve this in the future. thanks.
