iosXF 0 Posted October 31, 2019 Posted October 31, 2019 Hi guys I have a problem namely when entering on the server there is no content, the server on phones works but does not work on a machine Apple TV The picture shows more, thanks
Luke 42241 Posted November 1, 2019 Posted November 1, 2019 Hi, it looks like you haven't actually connected to an emby server yet. Is it your emby server, or somebody else's? 1
ebr 16335 Posted November 1, 2019 Posted November 1, 2019 Hi. Looks like you logged in with Connect. Are you sure you have your Connect ID properly linked with a user on the server?
ebr 16335 Posted November 4, 2019 Posted November 4, 2019 I also have a problem Hi. Please describe the problem you are having. Thanks.
Senna 368 Posted November 4, 2019 Posted November 4, 2019 Hi. Please describe the problem you are having. Already two pages from him here with topic name There is a problem in Apple TV That problem seems to be still in progress, but without clear info there, makes it difficult for us, to solve his problem.
Luke 42241 Posted November 4, 2019 Posted November 4, 2019 This one here looks like he hasn't actually signed into any Emby Server.
ebr 16335 Posted November 5, 2019 Posted November 5, 2019 This one here looks like he hasn't actually signed into any Emby Server. Actually, it looks like he signed in with Connect but has no servers attached to that Connect account.
Luke 42241 Posted November 5, 2019 Posted November 5, 2019 Exactly yes. Have you linked your local user on your Emby Server with Emby Connect? https://github.com/MediaBrowser/Wiki/wiki/Emby-Connect#guide-for-users
iosXF 0 Posted November 5, 2019 Author Posted November 5, 2019 I have a server, no problem on my phone, but there is a problem on Apple TV
Luke 42241 Posted November 5, 2019 Posted November 5, 2019 Yea i understand, but it's possible you may have signed in without using Emby Connect on the phone. Have you performed the linking process that I mentioned above?
vdatanet 1619 Posted November 5, 2019 Posted November 5, 2019 (edited) What's your Apple TV host name? If that name contains non ASCII chars, login doesn't work. Edited November 5, 2019 by vdatanet
iosXF 0 Posted November 10, 2019 Author Posted November 10, 2019 Yea i understand, but it's possible you may have signed in without using Emby Connect on the phone. Have you performed the linking process that I mentioned above? Yes, I did it via this page https://emby.media/pin.html
iosXF 0 Posted November 10, 2019 Author Posted November 10, 2019 The problem is with most devices, not all
vdatanet 1619 Posted November 10, 2019 Posted November 10, 2019 What's your Apple TV host name? If that name contains non ASCII chars, login doesn't work. Did you check this?
ebr 16335 Posted November 10, 2019 Posted November 10, 2019 Yes, I did it via this page https://emby.media/pin.html Hi. That is not the linking process he was referring to. Before that page will work, you need to be sure that your local Emby Server user is properly linked to your Emby Connect account. This is performed in the server dashboard as outlined in the document Luke linked to.
