vdatanet 1619 Posted October 31, 2019 Posted October 31, 2019 Hi, I'm planning to use Live TV with Emby. I want to sign up for Schedules Direct as a guide provider, but I see this: So, my question is Can I use Schedules Direct as data source for Guide TV?
Luke 42234 Posted October 31, 2019 Posted October 31, 2019 In the immediate short term, yes, but eventually they will disable our api key, so you're probably better off figuring out an xml based solution.
Sammy 791 Posted October 31, 2019 Posted October 31, 2019 You can use epg123 with ShedulesDirect to write an xmltv file that Emby can use. With epg123 you can customize your guide channel numbers too but I think I read someplace that this will be in a future Emby release.
Spaceboy 2573 Posted November 1, 2019 Posted November 1, 2019 Yes I still use SD data through epg123 Sent from my SM-T510 using Tapatalk
vdatanet 1619 Posted November 2, 2019 Author Posted November 2, 2019 Thanks, I will use Schedules Direct, if they disable it, I will find another solution.
ebr 16331 Posted November 3, 2019 Posted November 3, 2019 Direct support for SD in our interface will probably go away sometime fairly soon as it will have been an entire year since we added our own direct support. You could still use it through other products if you wish. Just FYI.
vdatanet 1619 Posted November 3, 2019 Author Posted November 3, 2019 Yes, but direct support is limited to United States, Canada and the United Kingdom. Please don't remove SD until you support more countries.
ebr 16331 Posted November 3, 2019 Posted November 3, 2019 Yes, but direct support is limited to United States, Canada and the United Kingdom. Please don't remove SD until you support more countries. It isn't our choice. The only reason you should be using SD now is if you had a subscription prior to our adding GN support. Officially SD is not supported for any new subscriptions. You can, however, use one of the other methods mentioned above.
vdatanet 1619 Posted November 4, 2019 Author Posted November 4, 2019 I've finally managed to use SD with XMLTV, using tv_grab_zz_sdjson included in the package xmltv for Ubuntu. Thanks!
vdatanet 1619 Posted November 4, 2019 Author Posted November 4, 2019 Using SD these TV programs showed images. Using XMLTV images are not shown. Where do these images came from?
Spaceboy 2573 Posted November 4, 2019 Posted November 4, 2019 Using SD these TV programs showed images. Using XMLTV images are not shown. Where do these images came from? in epg123 there are options to use the art urls of SD
vdatanet 1619 Posted November 4, 2019 Author Posted November 4, 2019 (edited) in epg123 there are options to use the art urls of SD Thanks, finally I've found a fork, tv_grab_az_sdjson_sqlite that supports artwork grab, and now I have artwork! Edited November 4, 2019 by vdatanet 1
