Happy2Play 9806 Posted October 28, 2019 Posted October 28, 2019 i cant uninstall emby from the pc What happens when you try? Are there error messages?
cmfromohio56 0 Posted October 28, 2019 Author Posted October 28, 2019 (edited) What happens when you try? Are there error messages? yes when i was on emby Beta it wobt rec so when back to Version 4.2.1.0 now it work again i dont know if do with the update yestesday or what it was work on saturday Edited October 28, 2019 by cmfromohio56
cmfromohio56 0 Posted October 28, 2019 Author Posted October 28, 2019 Why did you roll back? because it quit work it wont rec anything
Luke 42217 Posted October 28, 2019 Posted October 28, 2019 Why not be a good beta tester and report your issue?
cmfromohio56 0 Posted October 28, 2019 Author Posted October 28, 2019 Why not be a good beta tester and report your issue? ya me be dumb lol
