bloodtaker 71 Posted June 9, 2014 Posted June 9, 2014 This is where I will put up many stock PSD's that you can use with no restrictions. Each one is made in Photoshop CS4 so some form of photoshop is needed to edit the files as they are smart layers. If you need it with the smart layers turned off let me know. 1
bloodtaker 71 Posted June 9, 2014 Author Posted June 9, 2014 (edited) The first one up on the block is the movie clapper in hi res. This is loosely based off of Xzener's idea just a much higher res template. It has not been turned so that you can set it up how you want. If you need help with editing this template let me know and I can walk you through it. Dimensions of this are 2578 by 2036. 4.94mb unpacked 1.17mb packed Download You will need the Gotham Font for this if you want to keep it in the style created or use your own style font. You can get the font here from the github. https://github.com/MediaBrowser/MediaBrowser/wiki/assets#mediabrowser-logo-font Edited June 9, 2014 by bloodtaker 3
bloodtaker 71 Posted June 9, 2014 Author Posted June 9, 2014 (edited) Something that I am working on. 4096x4096 DVD/Blu Ray Disk template Edited June 9, 2014 by bloodtaker
