BillOatman 597 Posted October 27, 2019 Posted October 27, 2019 (edited) Hi: I'd like the ability to show up to 4 streams simultaneously on my TV. Like this: Edited October 27, 2019 by BillOatman
atomicmoon 152 Posted October 27, 2019 Posted October 27, 2019 (edited) This is able to be done with a simple HTML script placing each instance in an iframe. I will try to locate the code and share.Sent from my Pixel XL using Tapatalk *EDIT* I've attached an html file that just needs edited with your server address. I've left in place holders, and an example on the 4th screen of how the URL should look. Emby Quad Screen.html Edited October 27, 2019 by atomicmoon 1
BillOatman 597 Posted October 27, 2019 Author Posted October 27, 2019 Thanks @@atomicmoon, that's very helpful! But I was hoping for built in support so I could use it on my shield for example
