gav1 1 Posted October 26, 2019 Posted October 26, 2019 when turn on my screen just has select server but when press wake unable to connect to server can anyone help please
lorac 119 Posted October 26, 2019 Posted October 26, 2019 Local or remote server? Do you have access to the PC server is running on? We're going to need a better description of the problem before we can help. Sent from my ONEPLUS A6003 using Tapatalk
Luke 42217 Posted October 26, 2019 Posted October 26, 2019 Hi there, have you installed Emby Server? If so, is it running?
lorac 119 Posted October 26, 2019 Posted October 26, 2019 No. I don't see any attachments on your posts. Sent from my ONEPLUS A6003 using Tapatalk
Luke 42217 Posted October 26, 2019 Posted October 26, 2019 Is Emby Server running on Owner-PC? Is that your Emby Server?
gav1 1 Posted October 26, 2019 Author Posted October 26, 2019 i just downloaded that other day this morning everything was working fine on my nvidia shield where i first put it on
Luke 42217 Posted October 26, 2019 Posted October 26, 2019 What machine is Emby Server running on? Is Emby Server actively running? Are you able to use the Emby Server web interface right now?
gav1 1 Posted October 26, 2019 Author Posted October 26, 2019 i normally hav my emby on nvidia shield just come up the screenshot i showed u
Luke 42217 Posted October 26, 2019 Posted October 26, 2019 i normally hav my emby on nvidia shield just come up the screenshot i showed u No, that is our media player app on the Shield. You still need Emby Server as well, which you could put on your PC, or also on your Shield if you wish. Emby has two distinct parts: Server — Store your media library in a central place Client — Clients or Apps that play back media from the Emby Server From our quick start guide: A fully-functioning Emby system requires both a Server and at least one client player. The Server includes the Emby web app which is used to manage the Server and your media library. It also features a media player, thus the minimal installation of just the server is enough to get started, but most people will want to install Emby apps on other devices for expanded client functionality.
gav1 1 Posted October 26, 2019 Author Posted October 26, 2019 i understand what u r saying but my emby has been working brill for a month now was on this morning now it is like this
Luke 42217 Posted October 26, 2019 Posted October 26, 2019 Can you please answer this question from earlier? What machine is Emby Server running on? Is Emby Server actively running? Are you able to use the Emby Server web interface right now?
gav1 1 Posted October 26, 2019 Author Posted October 26, 2019 my m8 done everything for me i have just been using it
Solution gav1 1 Posted October 26, 2019 Author Solution Posted October 26, 2019 my m8 says he been in touch with whoever and he working on server so shud b bak up soon 1
Luke 42217 Posted October 27, 2019 Posted October 27, 2019 Ok, you are using our media player app on the Shield. You need to connect to an Emby Server, which could be your own, or somebody else's server.
