cm-mojo 1 Posted October 24, 2019 Posted October 24, 2019 Hi all - i'm trying to install EMBY Server on my 916+. i had it installed for about a day and then all of a sudden the Package would start and then instantly stop again. So I uninstalled Emby and tried to reinstall the package, but now although the package installs and shows as installed, it sits on 'GETTING STATUS' and I never get a Package Installed Successfully notification. If I reboot the NAS then the package doesn't appear to be installed. I'm just trying to find out where I can at least see the logs being generated during installation so I can try and troubleshoot whats going on.
FrostByte 5453 Posted October 24, 2019 Posted October 24, 2019 logs should be created here /var/packages/EmbyServer/target/var/logs
cm-mojo 1 Posted October 24, 2019 Author Posted October 24, 2019 that directory is not being created - making me think that the package installation isn't really happening - are there other logs?
cm-mojo 1 Posted October 24, 2019 Author Posted October 24, 2019 infact when i hit install it say 0% and then instantly goes to Getting Status, so i'm not even convinceed its trying to download the package - could the package be cached somewhere that i need to delete in order to force it to download again?
cm-mojo 1 Posted October 24, 2019 Author Posted October 24, 2019 i can see this in the fasibility log: 2019-10-24T23:40:00+01:00 MojoDs synoscgi_SYNO.Core.Package_1_feasibility_check[20170]: feasibility_check.cpp:87 FeasibilityCheck: [info] Start feasibility check [package_install] with type [hard].2019-10-24T23:40:00+01:00 MojoDs synoscgi_SYNO.Core.Package_1_feasibility_check[20170]: feasibility_check.cpp:106 FeasibilityCheck: [info] [0] of feasibility check [package_install] failed.2019-10-24T23:40:00+01:00 MojoDs synoscgi_SYNO.Core.Package_1_feasibility_check[20170]: feasibility_check.cpp:87 FeasibilityCheck: [info] Start feasibility check [package_install] with type [soft].2019-10-24T23:40:00+01:00 MojoDs synoscgi_SYNO.Core.Package_1_feasibility_check[20170]: feasibility_check.cpp:106 FeasibilityCheck: [info] [0] of feasibility check [package_install] failed.
Luke 42242 Posted November 3, 2019 Posted November 3, 2019 @@cm-mojo are you still having an issue with this?
Solution cm-mojo 1 Posted November 3, 2019 Author Solution Posted November 3, 2019 Hi, no I came to the conclusion there was something wrong with the repository, as it wasn't downloading properly. I waited a week and tried again and it came down correctly. It seems to be running nicely now. 1
cm-mojo 1 Posted November 27, 2019 Author Posted November 27, 2019 Hi Luke - I'm trying to update to the latest EMBY Synology version 4.3.0.30-1 and I'm seeing the same behaviour - I hit update, it says updating, but when I come back to it a few mins later, the package just shows RUNNING and it hasn't been upgraded at all - any ideas where I can look at the logs to see whats going on? The Emby Server logs don't show anything so I'm suspecting maybe an issue with the package?
Luke 42242 Posted November 27, 2019 Posted November 27, 2019 Can you please attach the emby server log? Thanks.
