spacecowboy2050 0 Posted October 24, 2019 Posted October 24, 2019 I am using a Homerun Connect Duo and all recordings are fine except when I record one particular show - Top Of The Pops from BBC4. Half way through (generally) on every episode I record the picture freezes, sound stops. After a while the picture returns with no sound, then when the sound returns it is out of sync completely. I know it's not a signal issue as other shows record from this channel fine. When I analyse the log in TSDoctor it appears there are packet issues/errors at the time when it freezes. I've attached the log. So frustrating that it's only this show that I get the problem with! Top of the Pops 1988-08-25 - 25 August 1988_check.log
Luke 42244 Posted October 24, 2019 Posted October 24, 2019 hi there, please attach the emby server log from the time of the recording. thanks.
spacecowboy2050 0 Posted October 24, 2019 Author Posted October 24, 2019 Is this the log you need? FYI the recording was 19.30-20.00 - was the same time as Eastenders was recording too if that could cause an issue? embyserver.txt
spacecowboy2050 0 Posted October 31, 2019 Author Posted October 31, 2019 Just tried again with this weeks episode. I actually recorded on plex this time but same thing happens. It starts to go wrong after about 10 minutes during the chart rundown and when playing the original TS file, the sound ends up well out of sync then eventually slots back in sync again. I've uploaded to google drive if anyone can take a look at the ts file. When you play it on Google Drive itself, there are a few pauses and stutters but sound generally stays in sync (I know Google has reencoded it) As I said ANY other recording is fine, even from this channel (BBC4HD). It's just this one show every single week that ends up with problems. https://drive.google.com/open?id=1XuIDNbDmxjD2FiC-5aD8M2_IePFKiw2G
spacecowboy2050 0 Posted November 1, 2019 Author Posted November 1, 2019 The charts - after about 10 mins of the video. It freezes and loses sync when they get to number 33 in the charts
spacecowboy2050 0 Posted November 1, 2019 Author Posted November 1, 2019 I recorded the repeat showing later on and it's even worse https://drive.google.com/open?id=1Zy4VzgdiTh-g2-Kxfco7yR4Qj62A9yCI I then recorded a range of different shows after this - all work fine. It's something about the stream of that particular show that messes it up but I can't find a fix.
spacecowboy2050 0 Posted November 1, 2019 Author Posted November 1, 2019 It can't be as every other show on that channel records perfectly
