igeoorge 26 Posted October 24, 2019 Posted October 24, 2019 Hi Is it possible to change the version of the movie inside the player of the movie itself? I wish I could switch the versions of the same movie inside the player, is it possible?
ebr 16313 Posted October 24, 2019 Posted October 24, 2019 Hi. No, you would have to go back to the detail screen but you can do that and then resume right where you were. Can I ask why you want to do this...?
igeoorge 26 Posted October 24, 2019 Author Posted October 24, 2019 I would like more convenience. It would be great to be able to change without leaving the player.
ebr 16313 Posted October 24, 2019 Posted October 24, 2019 Okay, but under what circumstance do you actually need to change versions during playback?
igeoorge 26 Posted October 24, 2019 Author Posted October 24, 2019 I have a cut version and another uncut version of the movie. It would be great to be able to switch between them within the player.
Luke 42217 Posted October 24, 2019 Posted October 24, 2019 In theory it makes some sense, but there would be a lot of complexity to it, especially considering that there are different purposes that multi-version can be used for.
igeoorge 26 Posted October 25, 2019 Author Posted October 25, 2019 (edited) Hi @@Luke Sometimes I don't think I use the platform to the best of my ability. Could you give examples of what we can do with this? Edited October 25, 2019 by igeoorge
Luke 42217 Posted October 25, 2019 Posted October 25, 2019 Some people use multi version for quality, others use it for different cuts. Those who use it for quality tend to want it to be more automatic.
