ebr 16334 Posted January 27, 2020 Posted January 27, 2020 This file works on my Android TV emby application but not on my Firestick for example. Is the difference between the two that the Android TV is direct playing or streaming while the Fire is transcoding?
Luke 42240 Posted January 28, 2020 Posted January 28, 2020 @@Tlsefred31 Can you please attach the emby server log as well? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Tlsefred31 0 Posted January 28, 2020 Posted January 28, 2020 (edited) @@Tlsefred31 Can you please attach the emby server log as well? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks. Hi, You will find below, my report for "Carnival Row" which is freezed, it's just an example on Chrome ffmpeg-transcode-b440282a-0c08-4ff1-854d-9bb3784fdaf2_1.txt Edited January 28, 2020 by Tlsefred31
Tlsefred31 0 Posted January 28, 2020 Posted January 28, 2020 (edited) @@Tlsefred31 Can you please attach the emby server log as well? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks. And here, reports for Amazon Fire stick for the same file, and same issue ffmpeg-transcode-7fc32f31-aea0-40e4-949b-01d32c2a687e_1.txt ffmpeg-transcode-2109bf62-36e2-49cc-95c6-007931450356_1.txt Edited January 28, 2020 by Tlsefred31
Tlsefred31 0 Posted January 29, 2020 Posted January 29, 2020 (edited) @@Tlsefred31 Can you please attach the emby server log as well? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks. I sent you a report from my Android TV, using my Emby name "Tlsefred31" juste now 19h37 (French hour) Movie watched is "le dictateur" and my issue is that the sound works perfect but the video is too slow and is too far behind the sound. This file is ok with Chrome. Edited January 29, 2020 by Tlsefred31
Nokia6 0 Posted January 30, 2020 Author Posted January 30, 2020 Bonjour Je viens de supprimer Emby du Nas avec tous ses composant et je l'ai réinstallé. Toujours le freeze à 71 minutes. ffmpeg-transcode-dd67e0d1-5867-4a45-877f-07f642a3b22b_1.txt ffmpeg-transcode-f1f20176-c211-40b2-95a4-f2f7e830c415_1.txt
ebr 16334 Posted January 30, 2020 Posted January 30, 2020 I sent you a report from my Android TV, using my Emby name "Tlsefred31" juste now 19h37 (French hour) Movie watched is "le dictateur" and my issue is that the sound works perfect but the video is too slow and is too far behind the sound. This file is ok with Chrome. Hi. There was no playback in that app log. However, whatever this is must be on the server/ffmpeg end (or somewhere in between) since it is seen in mulitple apps. Thanks.
Tlsefred31 0 Posted January 30, 2020 Posted January 30, 2020 Hi. There was no playback in that app log. However, whatever this is must be on the server/ffmpeg end (or somewhere in between) since it is seen in mulitple apps. Thanks. Ok, sorry I will try to send you a report when I would find a new issue for my Android TV But here you can find attached, new reports regarding a freeze problem around 71 minutes for a movie on my Amazon Fire stick ffmpeg-transcode-29303d75-2ba4-457b-9996-67d475aaa537_1.txt ffmpeg-transcode-bc1ffd0b-80f1-43d3-8d17-76f5f2f757bf_1.txt
Luke 42240 Posted January 31, 2020 Posted January 31, 2020 Ok, sorry I will try to send you a report when I would find a new issue for my Android TV But here you can find attached, new reports regarding a freeze problem around 71 minutes for a movie on my Amazon Fire stick Is this only happening on avi files?
Tlsefred31 0 Posted January 31, 2020 Posted January 31, 2020 (edited) Is this only happening on avi files? I will test several movies with avi and mkv file to be sure and confirm you. But just now, I tested a mkv file, and I have a freeze each 3 seconds since the beginning, you can see data in the attached file But for our topic, freeze around 71 minutes I will come back to you after a few test. ffmpeg-transcode-534ec7e2-0a9e-4798-a757-00a09e13f7fc_1.txt Edited January 31, 2020 by Tlsefred31
Nokia6 0 Posted January 31, 2020 Author Posted January 31, 2020 But for our topic, freeze around 71 minutes I will come back to you after a few test. Oui, ça serai bien. Parce que là, le sujet devie completement.
Tlsefred31 0 Posted January 31, 2020 Posted January 31, 2020 Oui, ça serai bien. Parce que là, le sujet devie completement. En effet, excuse moi De ton coté tu as vu une différence de freeze selon le format du fichier? J'ai pas encore fait des tests de mon coté.
Nokia6 0 Posted January 31, 2020 Author Posted January 31, 2020 Aucune. Mkv ou avi, c'est le même probleme. J'ai testé avec Chrome sur un pc windows, une Mibox 3 et une Mibox S avec l'app android tv, un Nokia 6 avec l'app android, c'est toujours le même probleme. il n'y a qu'avec l'addon Embycon sur Kodi que ça passe sans soucis.
Tlsefred31 0 Posted February 1, 2020 Posted February 1, 2020 Is this only happening on avi files? I sent you a report at 1h42 (french hour) with my Firestick amazon, using "Tlsefred31" as name, and movie is "Papy fait de la résistance" It"s a mkv file and I have a freeze issue with video and sound around 71/72 minutes also for this kind of file, not only for avi file
Luke 42240 Posted February 1, 2020 Posted February 1, 2020 Ok I would suggest trying again with the next release of emby server as there will be a lot of transcoding improvements. Thanks.
Tlsefred31 0 Posted February 1, 2020 Posted February 1, 2020 Do you know when we could expect this release ?
Luke 42240 Posted February 1, 2020 Posted February 1, 2020 No eta yet sorry. Hopefully in the next few weeks.
Tlsefred31 0 Posted February 12, 2020 Posted February 12, 2020 Hi, I've seen that Emby app on my Fire Stick has been updated the 30th of January, but it didn't resolved my issue regarding freeze around 71 min
Luke 42240 Posted February 12, 2020 Posted February 12, 2020 Yes please try again following the next release of emby server which will hopefully be soon. Thanks.
Tlsefred31 0 Posted February 13, 2020 Posted February 13, 2020 (edited) Okn I hope too I sent you a report at 15h51/52 (french hour) from my server Tlsefred31 on Fire Stick. It concerns also a freeze on a mkv file, but it"s a multiple freeze since the begining of the video "La Reine des Neiges 2" Currently, I'm trying to encode this video in mp4 HEVC to see if it's ok whith the format. Could you investigate on this please? Thanks in advance Edited February 13, 2020 by Tlsefred31
ebr 16334 Posted February 13, 2020 Posted February 13, 2020 Hi. We're fairly confident the issue is not on the app side so please test with the next release of the server when it is out. Thanks.
softworkz 5133 Posted February 24, 2020 Posted February 24, 2020 @Nokia6 - We were finally able to identify the problem. It should be fixed in the next beta. Thanks a lot for reporting! 1
maegibbons 1287 Posted February 24, 2020 Posted February 24, 2020 @@Nokia6 - We were finally able to identify the problem. It should be fixed in the next beta. Thanks a lot for reporting! Lets have a bit more info on what the problem was.... this was such a peculiar issue!! Krs Marj Sent from my SM-N976B using Tapatalk
softworkz 5133 Posted February 24, 2020 Posted February 24, 2020 The error was caused by a log message that we were printing from inside ffmpeg and the way certain format specifiers are handled by platform specific implementations of the standard C runtime. It wasn't too hard to spot but in an unexpected area so it has been discovered pretty late..
Tlsefred31 0 Posted February 25, 2020 Posted February 25, 2020 On my side, new release 4.3.1.0 has solved this problem for few movies, but not all. Hope, we could see an improvement with your future release.
