Quattroman20v 1 Posted February 29, 2020 Posted February 29, 2020 i mean for the Actual Version of Emby ;-)
Luke 42241 Posted February 29, 2020 Posted February 29, 2020 Hello Anyone have successfully run Emby on a X32X ( AL432 processors) I Have tried Arm64 and Beta Versions but Emby give Web error cant not reach the page ! Thanks Manuel Hi, is it actually an arm64 cpu?
Quattroman20v 1 Posted February 29, 2020 Posted February 29, 2020 Yes I’m running my new 832x with the actual firmware and only Emby 4.2.01 run on it the newer version don’t work Thanks Manuel
futuredriven07 0 Posted March 2, 2020 Posted March 2, 2020 (edited) Don't want to hijack but I can confirm this on a two AMD x64 model QNAPS: TVS-473 TS-1277 I attempted both the emby-server-qnap_4.3.1.0_x86_64.qpkg and emby-server-qnap_4.4.0.19_x86_64.qpkg, both give the same web error "This site can't be reached". Moving over from Plex, love what I've seen so far, hoping to use the native plugin over docker. Thanks for the support! Edited March 2, 2020 by futuredriven07
alucryd 318 Posted March 3, 2020 Posted March 3, 2020 (edited) Could you guys post some emby logs from the last known running version? I'd like to know what dotnet runtime it was using. Edited March 3, 2020 by alucryd
Quattroman20v 1 Posted March 3, 2020 Posted March 3, 2020 can you tell me the location of Logs i cant find /share/MD0_DATA/.qpkg/EmbyServer/programdata/logs /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/logs
PenkethBoy 2068 Posted March 3, 2020 Posted March 3, 2020 you can get them from the server dashboard>advanced>logs and you can see the path in the server dashboard to where your logs are located if thats not /share/MD0_DATA/.qpkg/EmbyServer/programdata/logs
Quattroman20v 1 Posted March 3, 2020 Posted March 3, 2020 it seems to be installed in this location but i have no logfile Informationen 2020/03/03 19:06:16 System 127.0.0.1 App Center App Installation [App Center] Installed Emby Server 4.3.0.30 in "/share/CACHEDEV1_DATA/.qpkg/EmbyServer".
Luke 42241 Posted March 3, 2020 Posted March 3, 2020 What alucryd is asking is for the users of 4.2.0.1 to provide a server log, which you can get from the emby web interface. No need to go poking around in the folders. Thanks.
Quattroman20v 1 Posted March 3, 2020 Posted March 3, 2020 Sorry my English is not so good when i running version 4.2.01 Emby work al the other other versions doesn´d i cant only post the Log of Version 4.2.01 , because i dont find the other Logs
Luke 42241 Posted March 3, 2020 Posted March 3, 2020 i cant only post the Log of Version 4.2.01 Yes you can, you can get it from your Emby web interface in the Log section.
smarts_vauva 0 Posted March 10, 2020 Posted March 10, 2020 Hello i have a qnap ts-832X 16gb Ram and 4x4 TB Raid 6 Run Emby on this or not i have over 100 000 Titels Mp3/Mp4/AAC/Flac/
Quattroman20v 1 Posted March 10, 2020 Posted March 10, 2020 Hello Luke The Last Beta dont run on it Only the Version Postet #22 work Thanks Manuel
Luke 42241 Posted November 1, 2020 Posted November 1, 2020 Can you try the latest beta server and let me know if this resolves the issue? Thanks !
sheepman_01 0 Posted November 2, 2020 Posted November 2, 2020 1 hour ago, Luke said: Can you try the latest beta server and let me know if this resolves the issue? Thanks ! I tried the emby-server-qnap_4.6.0.4_arm_64.qpkg is resolved the issue.Thanks
