angryblue 2 Posted October 24, 2019 Posted October 24, 2019 (edited) Hello, I have installed the latest version of the Emby server (QNAP Arm64 (aarch64) - BETA(emby-server-qnap_4.3.0.15_arm_64.qpkg) on my QNAP TS-832X (QTS 4.4.1.1086), and although the installation doesn't give any error, the server page on port 8096 gives connection error (I tried to restart the server and the NAS, to reinstall Emby ... and the problem continues). Thank you for your help. Edited October 24, 2019 by angryblue
Luke 42241 Posted October 24, 2019 Posted October 24, 2019 Hi, what was the previous version you were on?
angryblue 2 Posted October 24, 2019 Author Posted October 24, 2019 Hi, what was the previous version you were on? It was QTS 4.3.6.1070 Thank you for your reply.
Luke 42241 Posted October 24, 2019 Posted October 24, 2019 I mean what version of emby server, or is this your first install?
angryblue 2 Posted October 24, 2019 Author Posted October 24, 2019 I mean what version of emby server, or is this your first install? Yes,this is my first install.
Luke 42241 Posted October 25, 2019 Posted October 25, 2019 Is any emby server log file generated under /share/MD0_DATA/.qpkg/EmbyServer/programdata/logs ?
angryblue 2 Posted October 29, 2019 Author Posted October 29, 2019 Is any emby server log file generated under /share/MD0_DATA/.qpkg/EmbyServer/programdata/logs ? there is no log file, the programdata folder is empty.
angryblue 2 Posted October 30, 2019 Author Posted October 30, 2019 Can you try the new beta install? Thanks. Hi,I installed the new beta emby-server-qnap_4.3.0.17_arm_64.qpkg, sitll nothing in programdata.
Luke 42241 Posted October 30, 2019 Posted October 30, 2019 Did you start emby server after installing it?
angryblue 2 Posted October 30, 2019 Author Posted October 30, 2019 Did you start emby server after installing it? Yes,and I try to stop it, than start again, still doen't work.
sheepman_01 0 Posted November 14, 2019 Posted November 14, 2019 (edited) Can you try the new beta install? Thanks. I also couldn't start the emby server on QNAP ts-832x (QTS 4.3.6 or 4.4.1). The last version of the emby server I can run on QNAP is [emby-server-qnap_4.2.0.1_arm_64.qpkg]. After testing several versions, all of they didn't work. For example:[emby-server-qnap-4.2.1.0 arm-64.qpkg] or [emby-server-qnap-4.3.0.xx arm-64.qpkg] Edited November 14, 2019 by sheepman_01
Luke 42241 Posted November 14, 2019 Posted November 14, 2019 I also couldn't start the emby server on QNAP ts-832x (QTS 4.3.6 or 4.4.1). The last version of the emby server I can run on QNAP is [emby-server-qnap_4.2.0.1_arm_64.qpkg]. After testing several versions, all of they didn't work. For example:[emby-server-qnap-4.2.1.0 arm-64.qpkg] or [emby-server-qnap-4.3.0.xx arm-64.qpkg] Hi, what happened when you tried to run it?
sheepman_01 0 Posted November 14, 2019 Posted November 14, 2019 Hi, what happened when you tried to run it?Nothing happened, no CPU in used, no RAM in used, no logs
sheepman_01 0 Posted November 14, 2019 Posted November 14, 2019 Hi, what happened when you tried to run it?but emby-server-qnap_4.2.0.1_arm_64.qpkg is worked fine
angryblue 2 Posted November 15, 2019 Author Posted November 15, 2019 but emby-server-qnap_4.2.0.1_arm_64.qpkg is worked fine Hi, I have the same issue. Thank you for your reply,I'd like to try the 4.2.0.1version. but I can't find a link to download the install file, could you upload the file for me? Thank you very much.
sheepman_01 0 Posted December 6, 2019 Posted December 6, 2019 Hi, what happened when you tried to run it? I tried uninstall the old version and install the emby-server-qnap_4.3.0.30_arm_64.qpkg , it also didn't work , I see there is no process of embyserver running and there is nothing in the /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata,also no logs.but the emby-server.pid had created in /var/run/ and had PID number in it
Luke 42241 Posted December 9, 2019 Posted December 9, 2019 HI there, please try re-downloading 4.3.0.30 again from our website and let me know if the patched version resolves things for you. Thanks !
sheepman_01 0 Posted December 9, 2019 Posted December 9, 2019 HI there, please try re-downloading 4.3.0.30 again from our website and let me know if the patched version resolves things for you. Thanks ! it also didn't work
sheepman_01 0 Posted December 20, 2019 Posted December 20, 2019 Thanks for the info. I tried the emby-server-qnap_4.3.1.0_arm_64.qpkg. it also didn't work!
sheepman_01 0 Posted December 20, 2019 Posted December 20, 2019 Hi, I have the same issue. Thank you for your reply,I'd like to try the 4.2.0.1version. but I can't find a link to download the install file, could you upload the file for me? Thank you very much. emby-server-qnap_4.2.0.1_arm_64.zip
angryblue 2 Posted January 6, 2020 Author Posted January 6, 2020 Hi, I have the same issue. Thank you for your reply,I'd like to try the 4.2.0.1version. but I can't find a link to download the install file, could you upload the file for me? Thank you very much. Thank you for your help
sheepman_01 0 Posted February 15, 2020 Posted February 15, 2020 Thanks for the info. I tried the emby-server-qnap_4.4.0.14_arm_64.qpkg. it also didn't work!
Quattroman20v 1 Posted February 29, 2020 Posted February 29, 2020 Hello Anyone have successfully run Emby on a X32X ( AL432 processors) I Have tried Arm64 and Beta Versions but Emby give Web error cant not reach the page ! Thanks Manuel
