cochize1 55 Posted October 22, 2019 Posted October 22, 2019 Is there any way to set a backdrop for the libraries to be chosen only from the series/movies from within given library? I.e. I have different libraries for regular TV Series, Carton Series or Looney Tunes. But the set of backdrop images doesn't vary per library so basically when accessing Cartoon Series or Looney Tunes the backdrop can be chosen from regular TV Series (sometimes dark and scary for the kids). Is there a way to set the backdrops to be chosen only from the series from within the given library so for Cartoon Series that would be only Simpsons, South Park etc. that are in this library and not any others?
Luke 42217 Posted October 23, 2019 Posted October 23, 2019 Hi, what exactly do you mean by backdrop? What emby app are you using?
cochize1 55 Posted October 23, 2019 Author Posted October 23, 2019 (edited) Sorry for the lack of details. I have my emby server set on Synology NAS and windows, I am not refering to any app. And what I mean is as shown on attached picture: - library only for Looney Tunes and the backdrop is from Orange is the New Black which is is other library (TV Shows). Is there a way that the backdrop image be chosen ONLY from the media within given library? Edited October 23, 2019 by cochize1
Happy2Play 9806 Posted October 23, 2019 Posted October 23, 2019 I do see the behavior shown above in 4.2.1.0. Backdrops not restricted to current library. This appears to work properly in beta 4.3.0.15. Only issue I see is it does not randomly go through the multiple backdrops, it only uses the first backdrop of each series. So if you have one series it does not rotate.
cochize1 55 Posted October 23, 2019 Author Posted October 23, 2019 Yeah, also forgot to mention I am on stable 4.2.1.0 version. So I guess I just have to wait for the official release. And by any chance do you know if the "backdrop missing (just grey background) after hitting the back arrow" issue is being worked on (as I was told by Luke some time ago) in this beta version?
cochize1 55 Posted November 19, 2019 Author Posted November 19, 2019 Just read changes in 4.3 beta versions and couldn't find it, is this being fixed in new release: 1. The issue of given backdrops per library from within specific library? 2. Backdrop on main page missing after hitting BACK arrow (page needs to be refreshed in the browser for backdrop to reappear again)
Luke 42217 Posted November 19, 2019 Posted November 19, 2019 Haven't had a chance to look at this yet but hopefully soon. Thanks.
cochize1 55 Posted December 2, 2019 Author Posted December 2, 2019 I believe the problem is solved now in Emby 4.3 as backdrops repopulate correctly but for some reason I have no backdrop at all for Mixed Content libraries
