deaerator 2 Posted June 8, 2014 Posted June 8, 2014 Media browser server cannot connect to next pvr "Status: Unavailable (The remote server returned an error: (500) Internal Server Error.)" Paste Bin Log http://pastebin.com/j22SPtVQ
Sven 136 Posted June 8, 2014 Posted June 8, 2014 It's installed on the same system? Nextpvr and MediaBrowser I see you use http://localhost:8866 as nextpvr server.
Sven 136 Posted June 8, 2014 Posted June 8, 2014 Yes, but is your next pvr installation on the same machine or on a different machine? If on another machine you need to go to the Plugins --> NextPvr and change the localhost to the ip of the remote server....
Sven 136 Posted June 8, 2014 Posted June 8, 2014 What do you get if you browse to http://localhost:8866 on that machine??
Luke 42239 Posted June 8, 2014 Posted June 8, 2014 looks like there is an issue with your next pvr installation. you might need those guys to help you. 1
rickn345 1 Posted November 16, 2014 Posted November 16, 2014 (edited) Hello, I have tried the same setup and receive the same error. Did you ever find a solution? -SOLVED- Checked Web Server in the client settings of Nextpvr. Used server name and password. Edited November 16, 2014 by rickn345
Sven 136 Posted November 16, 2014 Posted November 16, 2014 Can you explain it a little bit more? You get the same page as deaerator? Try to reinstall nextpvr...
UncleJohnsBand 1 Posted November 16, 2014 Posted November 16, 2014 Can you explain it a little bit more? You get the same page as deaerator? Try to reinstall nextpvr... Looks like probably a botched install of the web app... follow the instructions on the NPVR wiki for installing NEWA (web interface). The build that is on the wiki is the same that is shipping with the most current NPVR. http://www.gbpvr.com/nwiki/pmwiki.php?n=Manual.NEWA#toc4
