vaise 340 Posted October 20, 2019 Posted October 20, 2019 Is there any chance of having some control over the library type of 'Recordings' that default to mixed content ? Or not having it at all and allowing manual creation as 'Home Video's and Photos' type ? You cant change unless you re-create, and this is system created. The issue I am having is that I use Ombi and it is finding the content in this library and sending out newsletters with it included - but I dont want this as part of the Ombi system. I cant find anywhere in Ombi to control this.
vaise 340 Posted October 20, 2019 Author Posted October 20, 2019 Thanks, I did that now. Lets see if it resolves as a workaround for Ombi.
vaise 340 Posted October 21, 2019 Author Posted October 21, 2019 hhhhmmmm - OK - Wife complaining as the interface over the the 'Home Video's and Photos' she does not like. So - I need to set that back to the default mixed content which is the emby default and been fine. So..... Is there any way to limit ombi from being able to read the specific libraries, or to NOT read Mixed content libraries. It uses the Emby API key for access. I expect you to say its an Ombi issue...... but anything I can do 'outside of the box' ?
Luke 42244 Posted October 21, 2019 Posted October 21, 2019 I don't know too much about Ombi sorry. Currently creating an api key will give it access to all libraries but I suppose more control is possible for the future.
