Dedone 17 Posted October 19, 2019 Posted October 19, 2019 Hi everyone, I want to report a problem with the android TV app. I've start a video with Dolby plus and I'm not able reproduce it trough the soundbar (if I use the TV speaker everything work great). The same file launched with VLC on the same TV work with the soundbar perfectly. What does it mean?
EduardoSantos 40 Posted October 19, 2019 Posted October 19, 2019 (edited) On my Android TV long pressing remote's "ok" button (while movie is playing) will show casting info on screen. There you can check if casting is direct mode or transcoded. There is also info on the audio track (original/casting). I would check this to know whether problem is transcoding or some passthrough problem from Emby app to the soundbar. Edited October 19, 2019 by EduardoSantos
ebr 16338 Posted October 19, 2019 Posted October 19, 2019 Hi. Please provide specifics for an example. Thanks. How to Report a Problem
Dedone 17 Posted October 20, 2019 Author Posted October 20, 2019 (edited) As requested I pute more informations -audio doesn't work -if I play the same file always trough wifi in the same TV (Sony xf90) with VLC app everything work perfect -my setup is a synology ds218+ with the last stable build server -I've never encountered this problem with any other file Slet me know if you need other info and Tha KS for your support! Edited October 20, 2019 by Dedone
ebr 16338 Posted October 22, 2019 Posted October 22, 2019 How is the soundbar connected? If it is an optical connection, DD+ won't pass on that I don't think. You may need to adjust the audio setting on the device itself.
Dedone 17 Posted October 22, 2019 Author Posted October 22, 2019 How is the soundbar connected? If it is an optical connection, DD+ won't pass on that I don't think. You may need to adjust the audio setting on the device itself. Soundbar is connected trough hdmi (arc Sony soundbar on Sony TV). I've "solved" the situation by remuxing the files and now work propely.Maybe was a problem iside the file, i don't know. The difference is that i remux the files withou 6.1 channels and unfortunately i dont' have any other Dolby + file to test if was a problem of the file or in the app.
EduardoSantos 40 Posted October 22, 2019 Posted October 22, 2019 I think we may be missing something here. As requested I pute more informations-audio doesn't work-if I play the same file always trough wifi in the same TV (Sony xf90) with VLC app everything work perfect-my setup is a synology ds218+ with the last stable build server-I've never encountered this problem with any other fileSlet me know if you need other info and Tha KS for your support! So you do have some other media file containing Dolby+ audio and Emby is able to play it accordingly throughout the same configuration?
ebr 16338 Posted October 22, 2019 Posted October 22, 2019 Some ARC implementations wouldn't support 6.1. That was probably the issue.
Dedone 17 Posted October 22, 2019 Author Posted October 22, 2019 I think we may be missing something here. So you do have some other media file containing Dolby+ audio and Emby is able to play it accordingly throughout the same configuration? i'll search for something to test with
EduardoSantos 40 Posted October 22, 2019 Posted October 22, 2019 You can find downloadable sample test files here: https://thedigitaltheater.com/dolby-trailers/ In that page there is a link to a "Nature's Fury (Dolby Digital Plus ATMOS)" that might just be the case.
Dedone 17 Posted October 22, 2019 Author Posted October 22, 2019 Done, everything work perfect! It was a file problem. Thanks everyone for the fast and great support!!!!!!!!!!
