TeamB 2440 Posted June 27, 2021 Author Posted June 27, 2021 14 hours ago, amb13 said: Is this something you can add to the add-on? Would be hard to always have to add in manually. Do you have any clue why it would act so strange when I add the refresh token to the pluginpath? You might need to URL encode the refresh param like all the other params are plugin://plugin.video.embycon/ ?url=%7Bserver%7D/emby/Shows/NextUp%3FParentId%3Dbc3a7d1d3dac1f10e170387270df67fa%26Fields%3D%7Bfield_filters%7D%26ImageTypeLimit%3D1%26IsMissing%3DFalse%26IncludeItemTypes%3DEpisode%26Recursive%3DTrue%26format%3Djson%26Limit%3D%7BItemLimit%7D%26Userid%3D%7Buserid%7D%26SortBy%3DDateCreated%26SortOrder%3DDescending%26Filters%3DIsNotFolder%26Legacynextup%3Dtrue &mode=GET_CONTENT &media_type=Episodes &sort=none &name_format=Episode%7Cepisode_name_format &reload=$INFO[Window(Home).Property(plugin.video.embycon-embycon_widget_reload)] From This: &reload=$INFO[Window(Home).Property(plugin.video.embycon-embycon_widget_reload)] To This &reload=%24INFO%5BWindow%28Home%29.Property%28plugin.video.embycon-embycon_widget_reload%29%5D
amb13 18 Posted June 27, 2021 Posted June 27, 2021 5 hours ago, TeamB said: You might need to URL encode the refresh param like all the other params are plugin://plugin.video.embycon/ ?url=%7Bserver%7D/emby/Shows/NextUp%3FParentId%3Dbc3a7d1d3dac1f10e170387270df67fa%26Fields%3D%7Bfield_filters%7D%26ImageTypeLimit%3D1%26IsMissing%3DFalse%26IncludeItemTypes%3DEpisode%26Recursive%3DTrue%26format%3Djson%26Limit%3D%7BItemLimit%7D%26Userid%3D%7Buserid%7D%26SortBy%3DDateCreated%26SortOrder%3DDescending%26Filters%3DIsNotFolder%26Legacynextup%3Dtrue &mode=GET_CONTENT &media_type=Episodes &sort=none &name_format=Episode%7Cepisode_name_format &reload=$INFO[Window(Home).Property(plugin.video.embycon-embycon_widget_reload)] From This: &reload=$INFO[Window(Home).Property(plugin.video.embycon-embycon_widget_reload)] To This &reload=%24INFO%5BWindow%28Home%29.Property%28plugin.video.embycon-embycon_widget_reload%29%5D Thanks, tried this and this did not work at all now. When I go and add a widget to a link in embycon in my skin. Is that created link something embycon controlls? Could you add a refresh token to that, or are we stuck on the mercy of the script?
TeamB 2440 Posted June 27, 2021 Author Posted June 27, 2021 11 minutes ago, amb13 said: Thanks, tried this and this did not work at all now. When I go and add a widget to a link in embycon in my skin. Is that created link something embycon controlls? Could you add a refresh token to that, or are we stuck on the mercy of the script? yeah ok, looking at this again it looks like you dont need to url encode the text. The add-on links under the add-on main menu are controlled by the add-on so I may be able to add something however I dont know if it will help as you have pointed out the content changes. I would need to test this when I get time.
amb13 18 Posted June 27, 2021 Posted June 27, 2021 1 hour ago, TeamB said: yeah ok, looking at this again it looks like you dont need to url encode the text. The add-on links under the add-on main menu are controlled by the add-on so I may be able to add something however I dont know if it will help as you have pointed out the content changes. I would need to test this when I get time. OK. Thanks If you want to take a look at it I got it to work as I want it to with this: plugin://plugin.video.embycon/?url=%7Bserver%7D/emby/Shows/NextUp%3FParentId%3Dbc3a7d1d3dac1f10e170387270df67fa%26Fields%3D%7Bfield_filters%7D%26ImageTypeLimit%3D1%26IsMissing%3DFalse%26IncludeItemTypes%3DEpisode%26Recursive%3DTrue%26format%3Djson%26Limit%3D%7BItemLimit%7D%26Userid%3D%7Buserid%7D%26SortBy%3DDateCreated%26SortOrder%3DDescending%26Filters%3DIsNotFolder%26Legacynextup%3Dtrue&mode=WIDGET_CONTENT&type=nextup_episodes&sort=none&name_format=Episode%7Cepisode_name_format&reload=$INFO[Window(Home).Property(plugin.video.embycon-embycon_widget_reload)]",return) Istead of: plugin://plugin.video.embycon/?url=%7Bserver%7D/emby/Shows/NextUp%3FParentId%3Dbc3a7d1d3dac1f10e170387270df67fa%26Fields%3D%7Bfield_filters%7D%26ImageTypeLimit%3D1%26IsMissing%3DFalse%26IncludeItemTypes%3DEpisode%26Recursive%3DTrue%26format%3Djson%26Limit%3D%7BItemLimit%7D%26Userid%3D%7Buserid%7D%26SortBy%3DDateCreated%26SortOrder%3DDescending%26Filters%3DIsNotFolder%26Legacynextup%3Dtrue&mode=GET_CONTENT&media_type=Episodes&sort=none&name_format=Episode%7Cepisode_name_format&reload=$INFO[Window(Home).Property(plugin.video.embycon-embycon_widget_reload)] Using mode=WIDGET_CONTET and type=nextup_episodes instead of GET_CONTENT and media_type=Episodes as in estuary (embycon) Though I'm not sure I didn't ruin some other function with this.
TeamB 2440 Posted September 21, 2024 Author Posted September 21, 2024 (edited) I have moved the EmbyCon add-ons to a new repository hosted on GitHub https://faush01.github.io/embycon_kodi_repo/ Because of the move any existing clients using the old repository will need to install the new repository and then install EmbyCon again from the new repository to switch to the new repository to get updates. Install new repository Re-install the EmbyCon add-on from the new repository (no need to uninstall, just install over the top) Sorry for any confusion. Edited September 21, 2024 by TeamB
