Drego344 23 Posted October 18, 2019 Posted October 18, 2019 (edited) Emby for kodi was working fine and it just stop syncing my tvshows again. i tried repairing my library but no luck... logs attached. shows missing... how to get away with murder and law and order svu. emby logs 1018.txt Edited October 18, 2019 by Drego344
Luke 42234 Posted October 18, 2019 Posted October 18, 2019 Hi there, did you forget to attach the log?
Drego344 23 Posted October 18, 2019 Author Posted October 18, 2019 (edited) @@Luke miss that one.... its attached now Edited October 18, 2019 by Drego344
Drego344 23 Posted October 18, 2019 Author Posted October 18, 2019 i did a database reset, so im waiting to see if it will update when new episodes are added, then i will post the logs..
Drego344 23 Posted October 19, 2019 Author Posted October 19, 2019 (edited) @@Luke @@sualfred Still no luck.... its just my tvshows.....logs attach http://paste.kodi.tv/ulamiyapen Emby logs 1019.txt Edited October 19, 2019 by Drego344
sualfred 677 Posted October 19, 2019 Posted October 19, 2019 The Kodi log is saying that episodes were updated/synced. I've noticed you are using Embuary. Have you enabled the library tags for shows in the skin settings? See https://emby.media/community/index.php?/topic/64762-changelog-embuary-a-emby-kodi-skin/?p=796474
Drego344 23 Posted October 19, 2019 Author Posted October 19, 2019 (edited) @@sualfred i had the tags but custom hub was off, just turned it on, some of the shows were not updated....magnum pi and Hawaii five o do i need to repair the library? P.S. this is a fresh install of kodi Edited October 19, 2019 by Drego344
sualfred 677 Posted October 19, 2019 Posted October 19, 2019 Steps to test: -> refresh metadata on the entire show that won't be updated on the server and wait until kodi recognizes the change -> repair tv show db in Kodi via the Emby addon
Drego344 23 Posted October 21, 2019 Author Posted October 21, 2019 (edited) Still not syncing, also notice that the other day when i repair my library, it pull the shows i was missing, now i started up kodi and they are gone.... its syncing some shows but not some, im missing shark tank, supergirl, Hawaii five o and magnum pi kodi logs: http://paste.kodi.tv/ozacusomep emby logs 1021.txt Edited October 21, 2019 by Drego344
Luke 42234 Posted October 22, 2019 Posted October 22, 2019 Is looks like there's some activity there, no?
Drego344 23 Posted October 22, 2019 Author Posted October 22, 2019 i just don't understand whats going on...... i started kodi and the update started, i see i was missing the good doctor after the update, i went to the emby dashboard and did a meta refresh while kodi was open and the episode showed up, i shut down kodi and reopen, now the episode is gone, deleted.... im confused Kodi logs: http://paste.kodi.tv/mezudifire emby logs 1022.txt
Drego344 23 Posted October 23, 2019 Author Posted October 23, 2019 (edited) @@Angelblue05 @@Luke @@sualfred i think i figured out whats going on, i have my system setup to update quality when a better copy is available 720-1080p..... when the file is initially found emby for kodi will pick it up, but once it updates the quality, it deletes, the file and it wont show up in kodi, but its available on the emby dashboard... Edited October 23, 2019 by Drego344
sualfred 677 Posted October 23, 2019 Posted October 23, 2019 That's a known issue afaik. Angelblue05 is currently not available to look into it again. If the filename is the same nothing will break as far as I remember.
Luke 42234 Posted October 23, 2019 Posted October 23, 2019 Did you take a look at this thread? https://emby.media/community/index.php?/topic/78585-emby-libraries-not-syncing-to-kodi/
Drego344 23 Posted October 23, 2019 Author Posted October 23, 2019 @@Luke will this be in the next release, or how can i implement this?
Luke 42234 Posted October 23, 2019 Posted October 23, 2019 I think this still requires investigation. Thanks for reporting.
TeamB 2440 Posted October 23, 2019 Posted October 23, 2019 You should be able to edit and add this to you install, just look for the correct file and lines to add the changes. Report back with the outcome.
Drego344 23 Posted November 14, 2019 Author Posted November 14, 2019 @@Angelblue05 is there any fix for this yet.....whenever my episodes get upgraded to a better quality, they get deleted, have to keep repairing my library i have attached my kodi logs, also did a repair so that might also show in the logs.. http://paste.kodi.tv/egezalihoz
Angelblue05 4132 Posted November 14, 2019 Posted November 14, 2019 @@Angelblue05 is there any fix for this yet.....whenever my episodes get upgraded to a better quality, they get deleted, have to keep repairing my library i have attached my kodi logs, also did a repair so that might also show in the logs.. http://paste.kodi.tv/egezalihoz I see the episode was removed, but what is the episode title that should have replaced it? How can I replicate this here? EMBY.objects.core.tvshows -> DELETE episode [1191/188] 37380
Drego344 23 Posted November 14, 2019 Author Posted November 14, 2019 @@Angelblue05 it was one of the Chicago fire, pd or med, it does it on whatever series that gets updated to a higher quality
Angelblue05 4132 Posted November 14, 2019 Posted November 14, 2019 (edited) @@Angelblue05 it was one of the Chicago fire, pd or med, it does it on whatever series that gets updated to a higher quality Hm, but what is the title of the episode so I can make sense of your log activity? Thank you. Is the episode deleted first then the upgraded quality is then added? I see potentially emby treating the episode as stacked if both are there at the same time and Emby is able to pick up on it. Edited November 14, 2019 by Angelblue05
