eNES0nsEsK 15 Posted October 18, 2019 Posted October 18, 2019 Could we get swipe gesture functionally in the mobile apps that would enable adjustments of audio volume, screen brightness and playback position?I use VLC on android and they've implemented this well, it's simple, intuitive and a joy use.It's explained here, https://www.vlchelp.com/volume-brightness-seek-gestures-android/ 10
Luke 42242 Posted October 18, 2019 Posted October 18, 2019 Hi, we used to have these but I took them out because users were complaining of constantly accidentally tripping them. We can find a way to bring them back. I think a circular gesture would be a good compromise. 1
eNES0nsEsK 15 Posted October 22, 2019 Author Posted October 22, 2019 (edited) OK, totally understand you don't want to annoy people with gestures they don't want.Could you have a "Toggle Touch Gestures" option in the mobile app settings?This could default to being off so people don't trip them accidentally.I like idea of a circular gesture to control playback position. It would be good if it functioned like a jog wheel for video editing.Like this, https://www.amazon.com/Contour-Design-Shuttle-Xpress-Multimedia-Controller/dp/B0001DBEKGAlthough it doesn't need to be that accurate, but could allow quick navigation with a faster gesture, then a more slightly more accurate positioning with a slow gesture.The volume is probably less important to most people because we have easily accessible hardware buttons that can be used.The most useful gesture for me personally would be brightness control. This is tricky to adjust on my Android phone when I'm holding it horizontally and I've started playback I then need to swipe down from the top a few times to get to the brightness slider. Could a two or three fingered vertical swipe be used for this possibly?Anyway, just throwing some ideas around. Thanks for your hard work. Edited October 22, 2019 by eNES0nsEsK 1 1
Luke 42242 Posted October 22, 2019 Posted October 22, 2019 Yes that's possible, but a last resort. A circular gesture shouldn't have a problem of being accidentally triggered therefore it can just always be enabled.
theghost31 4 Posted November 11, 2020 Posted November 11, 2020 Hi Long time ago, I saw these features, since they disappeared, I'm still waiting them Do you know, when you will purpose their again? Even in option which is disabled by default? Thank you Regards
Luke 42242 Posted November 11, 2020 Posted November 11, 2020 Hi, yes it's something we'll look at in upcoming updates. Thanks for the feedback.
miniliQuid 95 Posted November 18, 2020 Posted November 18, 2020 definitely want the brightness back, never cared for the audio, cause like eNES0nsEsK said, got hardware buttons for that part 1
darkassassin07 674 Posted May 24, 2021 Posted May 24, 2021 No, god I hated this feature with a burning passion like many others.
Luke 42242 Posted May 24, 2021 Posted May 24, 2021 4 minutes ago, darkassassin07 said: No, god I hated this feature with a burning passion like many others. Please refrain from profanity as this is a family friendly environment. Thanks. 1
miniliQuid 95 Posted May 24, 2021 Posted May 24, 2021 4 hours ago, darkassassin07 said: No, god I hated this feature with a burning passion like many others. People don't hate the feature, just the fact it was to easy to hit by accident. However they already said it won't come back in the same form to prevent exactly that issue 1
mzramna 2 Posted June 26, 2021 Posted June 26, 2021 (edited) Why not Just crate a config into the Android cliente to enable or disable this feature and set the sensibility/activation area instead of remove such usefull feature? Edited June 26, 2021 by mzramna 1 1
DarKni8 41 Posted March 6, 2022 Posted March 6, 2022 +1 for this, and it can be enabled or disabled by tpggle to satisfy both audiences. 1
DarKni8 41 Posted March 8, 2022 Posted March 8, 2022 8 hours ago, SikSlayer said: It's been years... Once again. For the feature which was already there, It makes me wonder. Seeing the capabilities of devs after seeing skip intro/credit plugin by @chef and @rbjtechI have made peace with the fact that they just dont want to focus on small but valuable feature and have not set there priority straight.
wugeng668 5 Posted May 5, 2022 Posted May 5, 2022 On 10/19/2019 at 1:13 AM, Luke said: Hi, we used to have these but I took them out because users were complaining of constantly accidentally tripping them. We can find a way to bring them back. I think a circular gesture would be a good compromise. Hi,you can add the screen locking function ,refer to the Android player MX player . Another solution is to add the option of opening gesture in the Android client. After all, the best way to solve the problem is not to delete convenience 1 1
Luke 42242 Posted September 3, 2022 Posted September 3, 2022 Hi, brightness control will be back in the video player in the next updates to the Emby Android and iOS apps. Thanks. 1
newyorker 11 Posted July 9, 2025 Posted July 9, 2025 I like the idea of “immersive gesture control”, i.e. the ability to control various aspects of playback—such as seeking, volume, and brightness—without having to bring up the control overlay. It can bring fluid, distraction-free interaction. This is a common feature in many modern video apps. Currently, if you want to stop playback, you need to tap the screen to reveal the control overlay, then tap the stop button. Similarly, double-tapping to fast-forward 10 seconds also brings up the overlay, which is unnecessary. Adjusting brightness requires opening the overlay and interacting with the brightness slider. Swipe gestures really is the best answer. They allow users to fast-forward, rewind, or adjust volume and brightness seamlessly, without interrupting playback or revealing on-screen UI elements. Unfortunately, it seems the devs are reluctant to add it for years. I still kindly urge the team to reconsider implementing it—at least as a toggleable option in settings. Other than swipe gestures, many modern players offer alternatives that are worth considering , such as: Two-finger tap to toggle play/pause; Double-tapping seeking that doesn’t invoke the control overlay. 1
SyenLxyz 0 Posted 18 hours ago Posted 18 hours ago On 10/22/2019 at 5:23 PM, eNES0nsEsK said: OK, totally understand you don't want to annoy people with gestures they don't want. Could you have a "Toggle Touch Gestures" option in the mobile app settings? This could default to being off so people don't trip them accidentally. I like idea of a circular gesture to control playback position. It would be good if it functioned like a jog wheel for video editing. Like this, https://www.amazon.com/Contour-Design-Shuttle-Xpress-Multimedia-Controller/dp/B0001DBEKG Although it doesn't need to be that accurate, but could allow quick navigation with a faster gesture, then a more slightly more accurate positioning with a slow gesture. The volume is probably less important to most people because we have easily accessible hardware buttons that can be used. The most useful gesture for me personally would be brightness control. This is tricky to adjust on my Android phone when I'm holding it horizontally and I've started playback I then need to swipe down from the top a few times to get to the brightness slider. Could a two or three fingered vertical swipe be used for this possibly? Anyway, just throwing some ideas around. Thanks for your hard work. It's been many years that I've been waiting for this feature to come back, and I think this idea is the best compromise to accommodate both types of users: people who want the features and people who don't want the features. In my opinion, people who want the "Immersive Gesture Playback Controls" are usually the ones who are willing to spend time tinkering with the settings and to toggle certain features on/off. For Apple users, they may have the Infuse app that works perfectly well with Emby Server. However, as an Android user myself, the closest thing to Infuse I can find is Vidhub, it has the immersive gesture control just like Infuse but it is nowhere close to Infuse/Emby in terms of the automatic management of downloaded media like TV Shows, the downloaded media are not automatically grouped together into seasons and series, the downloads do not automatically include external subtitle files from the server, and the series can't be play successively one after another. My conclusion is that the original Emby for Android app is still the best app for watching downloaded media from Emby Server. I have been a lifetime Emby Premiere user for quite many years now and I really think that this feature would be a huge plus to many users who enjoy the immersive experience of gesture controls. So if there is any possible way that this feature can be brought back to life, I would sincerely be very grateful. Again, thank you for all the hard work and I truly appreciate everything that the Emby team has done.
