cperez90008 1 Posted October 16, 2019 Posted October 16, 2019 Hello Hey guys I have a question I am running Android 9 on my X96 S stick and my remote control does work with emby for android. I have it on y android 5 and 7 devices an everything works fine but for some reason I am only able to use my cursor on the android 9 device to select items. Typically this would not be an issue but on my live tv I am unable to scroll down my epg. Is there a fix for this? Is this common with anyone else running android 9? Any assistance I could get would be appreciated.
Sammy 791 Posted October 16, 2019 Posted October 16, 2019 This is an issue with using Android and not AndroidTV OS on the device, not with Emby.
Luke 42244 Posted October 17, 2019 Posted October 17, 2019 I think you've installed our mobile app. We have a dedicated app for TV devices: https://emby.media/emby-for-android-tv.html
cperez90008 1 Posted October 17, 2019 Author Posted October 17, 2019 I don't have the Android TV launcher so the Emby for Android TV doesn't work. When I loaded that it just gave me a black screen.
Luke 42244 Posted October 17, 2019 Posted October 17, 2019 Ok, we plan to add remote control support into the mobile app in the future. Thanks.
Timmayyy 2 Posted February 21, 2020 Posted February 21, 2020 This remote support would be much appreciated! Its unusable as is with a remote. Seems like it just needs the same screen type option as the windows theater platform.
GiGo 108 Posted February 22, 2020 Posted February 22, 2020 An 'Air Remote' works great with Emby with Android
