Oxide 139 Posted October 16, 2019 Posted October 16, 2019 It would be great if the On Now Widget on the home page would place favorite channels at the beginning just like the guide does, optional of course
Luke 42245 Posted October 16, 2019 Posted October 16, 2019 Hi, yes we'll be revamping sorting of this in an upcoming update. thanks. 1
Red5ive 30 Posted October 29, 2019 Posted October 29, 2019 Would be great to see this implemented soon. My 'On Next' section seems to pick obscure channels and radio stations for the ones it shows, most of which don't have a any fan art or epg listing for. It does make the section unsightly and useless: Kodi, using Emby plugin and Embuary skin do this right, having my main channels display first and it looks great. Hope this arrives soon!
Red5ive 30 Posted October 29, 2019 Posted October 29, 2019 Off topic but, the above image is from Emby running on Roku, why is the image for Live TV not the proper icon but a folder?
ebr 16337 Posted October 29, 2019 Posted October 29, 2019 Off topic but, the above image is from Emby running on Roku, why is the image for Live TV not the proper icon but a folder? Did you provide an image for that library? The system does not create one automatically.
Red5ive 30 Posted October 29, 2019 Posted October 29, 2019 It's not a user-created library though and on all other apps it has the TV icon on it like this:
ebr 16337 Posted October 29, 2019 Posted October 29, 2019 You can still add an image of your choosing. The Roku app is just showing a generic icon for a missing folder or library right now.
Red5ive 30 Posted October 29, 2019 Posted October 29, 2019 Ok, just seemed strange that all the other apps had an image for it. If I add one it will replace it for all apps yes? When do you estimate the On Now improvements will roll out?
Luke 42245 Posted October 29, 2019 Posted October 29, 2019 We'll make the icon consistent. Thanks for the feedback.
