lightsout 156 Posted June 8, 2014 Posted June 8, 2014 Is there a way for settings to stick for a specified user on multiple htpc's? Like theme, view settings etc. I know theme plugins are installed per pc so maybe that may be a problem. But I have to set everything up as far as how I like it visually on every computer I use. Wish this could just be done once.
Solution Abobader 3485 Posted June 8, 2014 Solution Posted June 8, 2014 Good day, Copy the profile settings from this locations: C:\Users\username\AppData\Roaming\MediaBrowser-Classic\Configurations *username = window login profile To the others computers, but consider that the other pc's have the same plugins, themes .. as the one you copy that profile settings from. My best 2
lightsout 156 Posted June 8, 2014 Author Posted June 8, 2014 Sweet!!!! Thanks a lot, that is great. Really enjoying the new MB has me tinkering with my htpc's again.
