speedingcheetah 39 Posted October 13, 2019 Posted October 13, 2019 Just trying out a Roku Ultra. The channels in the Guide are not in number order....how fix that? see 1st pic Also, how do u get it to look like Emby Theater does and its full screen On Now page < see 2nd pic
Solution ebr 16335 Posted October 13, 2019 Solution Posted October 13, 2019 Hi. When in the guide screen press the "*" key on your remote and select the sort order you would like. Thanks. 1
speedingcheetah 39 Posted October 13, 2019 Author Posted October 13, 2019 (edited) Hi. When in the guide screen press the "*" key on your remote and select the sort order you would like. Thanks. I actually just found that...however, it appears to not work correctly. I does not apply or save the settings, even when the box gets checked. It took at least 3 tries each to get each option to stick. Appears to be working now. Edited October 13, 2019 by speedingcheetah
speedingcheetah 39 Posted October 13, 2019 Author Posted October 13, 2019 What about the full screen Theater TV theme look? is is that exclusive to the web app and theater on pc only? I dont see a setting to change the Theme or style on Roku.
ebr 16335 Posted October 13, 2019 Posted October 13, 2019 Hi. We don't have themes in the Roku app yet but probably will in the future. You should be able to see the same content in the main Live TV library though.
Luke 42242 Posted October 17, 2019 Posted October 17, 2019 We will be revamping channel sorting in the near future. Thanks for the feedback. 1
