nath2 0 Posted October 12, 2019 Posted October 12, 2019 (edited) how could i use lan for stream my content from my pc to my xbox using lan cable because im currently using phone wifi hotspot and it bufffer alot Cabbe is plugged but keeping having internet on both device how do i do? Thanks Edited October 13, 2019 by nath2
Luke 42217 Posted October 13, 2019 Posted October 13, 2019 Hi ,have you installed Emby Server on your PC?
nath2 0 Posted October 13, 2019 Author Posted October 13, 2019 Yes everything is setup i would just like to switch to completly lan cable
the-dumb1 135 Posted October 13, 2019 Posted October 13, 2019 Have your Xbox connect to your Emby server with both being on the same LAN. Your phone acting as a wifi hotspot is not a relevant piece of information.
nath2 0 Posted October 13, 2019 Author Posted October 13, 2019 I currently have my phone tether to join my xbox to my emby but the quality of the wifi of the phone is very poor and short range. my content keep buffer/loading forever i have connected a lan cable from my pc(server) to my xbox im having trouble to get it to connect to emby
the-dumb1 135 Posted October 13, 2019 Posted October 13, 2019 Are you connecting your Xbox and your server computer directly to a router? I'd expect at least two Ethernet cables in that case, but it sounds like you're trying to directly connect a computer to your Xbox (you said you connected a LAN cable from your server to your Xbox). You need to describe the layout of your network. Start with your modem, your router, any network switches, how the Xbox is connected to the router or switch, and how the computer is connected to the router or switch.
nath2 0 Posted October 13, 2019 Author Posted October 13, 2019 i dont have router im using my phone as it
Happy2Play 9806 Posted October 13, 2019 Posted October 13, 2019 When you connect these devices via LAN together you are manually configuring all the network information, correct?
the-dumb1 135 Posted October 14, 2019 Posted October 14, 2019 When you connect these devices via LAN together you are manually configuring all the network information, correct? I doubt this is likely. Having a router with DHCP enabled would simplify things ... but without that manual configuration is required. What the original poster needs is a static local IP address for each device.
Luke 42217 Posted October 14, 2019 Posted October 14, 2019 What the original poster needs is a static local IP address for each device. @@nath2 have you tried this?
