stevedawg85 2 Posted October 11, 2019 Posted October 11, 2019 https://pastebin.com/AQaxSKV8 Above is a log of hopefully what will help. I tried watching 2 channels, ESPN & FS1 it'll open for 15-20 seconds, then stop and return to guide. I'll open the other channel, and it does the same thing. At the moment, I am away from home trying to watch via Chrome browser. But this also happened when I was in home / same network on a Fire Stick.
ebr 16337 Posted October 11, 2019 Posted October 11, 2019 Hi. The issue appears to be with your provider but I would also upgrade your Emby server to the latest release. [http @ 0x1c96d00] HTTP error 403 Forbidden
stevedawg85 2 Posted October 11, 2019 Author Posted October 11, 2019 Hmm, wonder why that is, I can stream the channel just fine w/ their APK. Also thinking of doing the m3u w/ tivimate for more results. I'll also update the server to see if it helps. thanks! may post back soon w/ more info!
PeteLocky 22 Posted October 12, 2019 Posted October 12, 2019 As ever said that's the provider what I would say is most probably it is the http referrer so change it to match what it is on the providers app
stevedawg85 2 Posted October 13, 2019 Author Posted October 13, 2019 So far, I was only able to upgrade the Emby server and problem still exists. I also want to say it seems more stable when I use Emby on Roku, but on the browser and Fire stick, it'll have the problem. I haven't had a chance to work on the other items, i'll check on the http thing. Thanks, will post updates when I get around to more troubleshooting.
Luke 42245 Posted October 14, 2019 Posted October 14, 2019 So far, I was only able to upgrade the Emby server and problem still exists. I also want to say it seems more stable when I use Emby on Roku, but on the browser and Fire stick, it'll have the problem. I haven't had a chance to work on the other items, i'll check on the http thing. Thanks, will post updates when I get around to more troubleshooting. Have you looked into what others have said about your provider? You may have to use the user agent configuration to disguise Emby Server so they don't reject it. @@Senna may have some tips on that.
stevedawg85 2 Posted October 14, 2019 Author Posted October 14, 2019 Have you looked into what others have said about your provider? You may have to use the user agent configuration to disguise Emby Server so they don't reject it. @@Senna may have some tips on that. @@Senna (how do I tag) can you help w/ this? How can I find out what to put in for HTTP referrer? The app is an apk, do I need to have a program monitoring my network traffic? I'm using the URL my service provided to me specifically for M3U services.
stevedawg85 2 Posted October 14, 2019 Author Posted October 14, 2019 Try this, this is my go to VLC/3.0.3 thanks, but no luck, I also tried some mozilla string I found. I'm putting this in the user agent header in for the tuner and the XML. (Nothing yet for referrer, because, not sure what to put in that one)
PeteLocky 22 Posted October 14, 2019 Posted October 14, 2019 Put it in the referer it is defo the referer if the app works normal via apk
stevedawg85 2 Posted October 15, 2019 Author Posted October 15, 2019 (edited) Put it in the referer it is defo the referer if the app works normal via apk Nope still no luck, I tried other headers also. I tried only typing in the referrer, typed in both, included and not included in the XML. Below is from my log, this is how it's supposed to look right? "RequiredHttpHeaders":{"User-Agent":"VLC/3.0.1","Referrer":"VLC/3.0.3"},"ReadAtNativeFramerate":false} and the error: [http @ 0x2329c80] HTTP error 403 Forbidden [hls,applehttp @ 0x2298ec0] Failed to reload playlist 0 elapsed=00:00:11.45 frame= 1209 fps=106 q=31.0 size= 2228kB time=00:00:20.22 bitrate= 902.4kbits/s dup=2 drop=0 throttle=off speed=1.77x [hls,applehttp @ 0x2298ec0] Opening 'http://104.218.60.164:83/live/zzz/yyy/254372.m3u8?token=Q0ZaWEpdEAkSBVUGUgtTVldYUA0KBgcCA1IBB1QAAVNaXAJfXwQCAFFBThRATRYGUAxtXVYUCFYEBwdWBxwWF0sBQGZQURAJEltTBwEOV0EdQ0ZdX1MQXgEfFhFcVBZYGlcDCA8GEB8SBhpCVksKAl0+VlFEX1EBEwlaFFlcGEBXCm1dXFhTXVRBWBQDG0hBWBJCFghYRwhdHxYDXERGA0wBEAMbAQsCA0FOFFBWEQ1FE0sWCBRnNxMfFgRNRFEMSw1dVxsPEF4DFloUHxsNEG4TV0dGRFcFXFZGQw8SBEAURl9YQWpRXF4NB1VHUAsNQkMIFgMUHkZcXFoIQV9GPUgNVhsDFwMCAVJUFE4=' for reading Edited October 16, 2019 by stevedawg85
Luke 42245 Posted October 15, 2019 Posted October 15, 2019 Please make sure to attach complete log file examples. thanks.
