zsurfaraz 4 Posted October 11, 2019 Posted October 11, 2019 Hi All, When I go to add a guide data link from my iptv provider, I am asked to choose a country. I choose the country, but then only the guide data for that countrys' channels is updated. Even though the link has multiple countries guide data. Can you please advise how to resolve this?
mark-in-dallas 87 Posted October 11, 2019 Posted October 11, 2019 You would need to create separate guides for each country, then you will probably have to go into each guide and remap the channels, because the IPTV providers channel ID's are not going to match the guide data provider channel ID's.
Solution ebr 16332 Posted October 11, 2019 Solution Posted October 11, 2019 Okay, I can see how that's not completely intuitive but we ask the country first so that we can determine exactly what types of guide data are available for you. Just select your country and then a new drop down will appear and you should select "XMLTV Data" and fill in your guide data url. Thanks.
zsurfaraz 4 Posted October 11, 2019 Author Posted October 11, 2019 thank you for your help, this has worked
