MndWrp 101 Posted June 7, 2014 Posted June 7, 2014 Hi there mb3 people ! i've been lunrking for a while in the forums but i finally took the pluge and here i am .. writing and everything! great software btw! the one i like best out of the other ones i tried (xbmc and plex) i'm in the process of building my library and i've come across a little thing i can't figure out yet i have episodes that have special features specifically about those episodes (a little making of kinda thing for that one show) i was hoping to get something like; i enter my season folder, in this i have the episodes, and within each episode having not only acces to Overwiew and scenes but Special Features as well much like it already is for movies.. here's hoping i was clear enough !! thanks for the help!
Koleckai Silvestri 1154 Posted June 7, 2014 Posted June 7, 2014 It works a bit differently for television series. You put all the specials in a Season 00 folder. Then you can adjust their metadata so they appear in a specific order with the other seasons. This is how the metadata provider has things organized as well. Look up your series on thetvdb.com and look at the Specials section.
MndWrp 101 Posted June 7, 2014 Author Posted June 7, 2014 I tried that and the features im talking about are unlisted... (Seinfeld.. Lots of episodes and about one feature each) ... I sure was hoping that was possible on the episode level.. The way it is now with season0 works great for show and season specials but for episode specific specials it adds a lot of clutter to an episode list... I guess ill keep them out of "the season they aired in" then Thanks!
