Sacwoo 0 Posted October 8, 2019 Posted October 8, 2019 I use Emby connect to be able to login and see my server and connect without manually adding the ip. A few weeks ago, it was saying my server was offline via emby connect so I removed the server and connected by manually adding the IP address and it works. How can I get the server resynced with emby connect? Can't seem to find hope to do this like I could during the setup.
ErikaJ 65 Posted October 8, 2019 Posted October 8, 2019 Good Day...I gather you do have an Emby Connect account? Cheers
Sacwoo 0 Posted October 8, 2019 Author Posted October 8, 2019 Correct, I have an account and sign in works
ErikaJ 65 Posted October 8, 2019 Posted October 8, 2019 Okay. Try going here to connect http://app.emby.media
Solution ebr 16313 Posted October 8, 2019 Solution Posted October 8, 2019 Hi. Your server's IP address may have changed or, maybe firewall or router configuration has changed. Make sure the WAN address shown on your dashboard is correct. Then go to your user configuration and blank out and save the "Emby Connect username" then re-input it and save. Now re-login via Connect and see if it works.
ErikaJ 65 Posted October 8, 2019 Posted October 8, 2019 If that doesn't work for you then you will need to get another invite in order to sync. Cheers
Sacwoo 0 Posted October 11, 2019 Author Posted October 11, 2019 Yes, I had to find where to send a reauthorization to register it to connect again, that fixed it.
