Solution ebr 16313 Posted October 8, 2019 Solution Posted October 8, 2019 If you removed "\2 DAYS IN PARIS" folder from "D:\Movies1\DVD", and did a library scan, is it completely removed from Emby (UI and Search)? Please try the above and report back. Somehow these things are also being identified as multi-version items. Each one a part of the other. 1
embyuser102019 0 Posted October 9, 2019 Author Posted October 9, 2019 Please try the above and report back. Somehow these things are also being identified as multi-version items. Each one a part of the other. Hi, I removed all the folder paths for the "TV" (TV Shows) library and then all the folder paths for the "Movie & TV" library (Mixed Content). Then re-added the paths for "TV" and left the content as TV Shows. The re-added the paths for a new "Movies" library and set the content to "Movies". Allowed the scheduled library scans to complete over night and it seems to have sorted itself out. The "Home screen", "Collections", "latest movies", "latest TV" , and "next up" are all populated correctly. So not sure why this happened but hopefully it will survive the next update. Thank you all for your help. Unless you have any further advice we can close this issue.
