barong 6 Posted October 8, 2019 Posted October 8, 2019 (edited) I have noticed DD+ / E-AC3 Audio is not displayed correctly in the "Original Media Info" section of the playback info - see attached image. Bit Rate and Channel info isn't populating. Standard DD and Stereo AAC seem to work correctly. Audio Track data from media Info: ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 1 h 0 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 279 MiB (17%) Language : English Service kind : Complete Main Default : Yes Forced : No Edited October 8, 2019 by barong
ebr 16338 Posted October 8, 2019 Posted October 8, 2019 And what is shown in the media info section of the detail page on the web app?
barong 6 Posted October 8, 2019 Author Posted October 8, 2019 And what is shown in the media info section of the detail page on the web app? Correct info.
ebr 16338 Posted October 9, 2019 Posted October 9, 2019 Correct info. There is no Audio bitrate there either. Why the channels aren't seen by the app is a mystery though...
