MagicPinball 3 Posted October 7, 2019 Posted October 7, 2019 I am running Windows Emby version 4.2.1. I have been taking manual backups as directed. I recently had an issue with my dedicated HTPC and had to reset the PC. I reinstalled Emby Server, copied files from backup, started Emby and identified my 3 libraries and let it scan them. At this point all worked fined. Verified my Movies and TV Shows are all in Emby. All Movies and TV Shows showed unwatched. I went to use SQLite DB Browser and open the old library.db file and attached the new library.db file. Got the following error: Result: table newlib.UserDatas has 12 columns but 14 values were supplied At line 1: replace into newlib.UserDatas select * from UserDatas How can this be fixed?
Luke 42217 Posted October 7, 2019 Posted October 7, 2019 Hi, I suppose you could add the columns to the old database. That may work.
MagicPinball 3 Posted October 7, 2019 Author Posted October 7, 2019 No, the new library.db is missing 2 fields which are in the old library: key nvarchar, lastPlayedDate datetime Why does my old 4.2.1 library.db contain two additional fields? All I want to do is set the played flag for my played movies.
Happy2Play 9806 Posted October 8, 2019 Posted October 8, 2019 No, the new library.db is missing 2 fields which are in the old library: key nvarchar, lastPlayedDate datetime Why does my old 4.2.1 library.db contain two additional fields? All I want to do is set the played flag for my played movies. I would assume you have a install that is older then 4.2 (ie upgraded install from previous versions). Same discussions here with trying to do a manual migration without the plugin. I would assume if the plug can do it that is can be done manually also. https://emby.media/community/index.php?/topic/77238-unable-to-migrate-to-new-server/
