skidmarks 199 Posted October 7, 2019 Posted October 7, 2019 Is there a way to change the "random" trailer that is played in cinema mode? I have it set up to play one trailer, local only, prior to the movie starting. I have noticed that it does not appear to be random, but a preassigned movie trailer associated to a movie in a database somewhere. For example every Indiana Jones movie in the series appears to have another Indiana Jones movie assigned as the into trailer. Not only does that confuse my simple mind but why do i want to see the trailer for movie 4 in the series when i am watching movie 1. It's always the same cinema mode trailer. If there a way to "reshuffle" cinema mode and what trailers are associated and bound to them?
Solution Luke 42255 Posted October 7, 2019 Solution Posted October 7, 2019 There is no way. It's a combination of random as well as similar trailers. The pool of available trailers to choose from is not that large, so that's why you might see some repetition. 1
skidmarks 199 Posted October 7, 2019 Author Posted October 7, 2019 (edited) There is no way. It's a combination of random as well as similar trailers. The pool of available trailers to choose from is not that large, so that's why you might see some repetition. Thanks Luke... Wasn't going to uninstall the plug-in to test this. Figured it would just reduplicate the same scenario. The Custom intro paths is more important to me and that is random from my "pool" of available files. Edited October 7, 2019 by skidmarks
