theleven 1 Posted October 5, 2019 Posted October 5, 2019 I did not write down my pin code when I joined Emby Is there a way to generate a new one ?? I don't see it anywhere on my profile
ebr 16310 Posted October 5, 2019 Posted October 5, 2019 Hi. What PIN code? If you are talking about the one generated by an app for Connect login, a new one is created each time you re-login with Connect.
theleven 1 Posted October 5, 2019 Author Posted October 5, 2019 When I'm here at this screen I .... user & password but unable to enter a pin to submit
Happy2Play 9802 Posted October 5, 2019 Posted October 5, 2019 That is for the pin code generated by the device you are attempting to add your Connect user credentials to. Example when I click sign in with Connect on my Roku it generates a pin to be entered into that page you are showing above.
theleven 1 Posted October 5, 2019 Author Posted October 5, 2019 Ah ... I was over thinking it ...found the correct info ... great forum here ....very responsive ....thanks Admin's & Mod's 1
Carlo 4561 Posted September 15, 2020 Posted September 15, 2020 (edited) 2 hours ago, Gatos said: I can't get my registration pin Hi, Give us more info and show us what you've done. What device generated the PIN code? Is this YOUR device or someone else's device? Edited September 15, 2020 by cayars
