Dayve 0 Posted October 5, 2019 Posted October 5, 2019 I live in Canada and just wondering which provider everyone is using for the IPTV UK channels with Emby Guide Data? Say like sky net, cable or what.
ebr 16332 Posted October 5, 2019 Posted October 5, 2019 Hi. Doesn't whomever is providing the streams also provide data?
Dayve 0 Posted October 6, 2019 Author Posted October 6, 2019 Yes but there data is only good for one or two days of guide data. I'm using the emby guide data for US and Canada and it works great to see 14 days into the future. Just trying to find the right guide for the UK channels.Like which provided and zip code that is best for me. I put in the zip code of NE99 and then from the drop down list I'm not sure which provider to select.
Spaceboy 2573 Posted October 6, 2019 Posted October 6, 2019 I don't actually use the emby guide data but you should probably pick sky UK. I think they have the full list of available channels Sent from my SM-T510 using Tapatalk 1
Dayve 0 Posted October 7, 2019 Author Posted October 7, 2019 I don't actually use the emby guide data but you should probably pick sky UK. I think they have the full list of available channels Sent from my SM-T510 using Tapatalk Thanks. I will give that a try.
ErikaJ 65 Posted October 8, 2019 Posted October 8, 2019 Good Day...I use CF31 and Sky which gives me all the ones I need. Cheers 1
