remid12 5 Posted January 30, 2025 Posted January 30, 2025 On 12/13/2023 at 8:20 AM, DaveM77 said: For anyone who stumbles across it wondering if it still works - I followed this today for doing the same (I had to update a path for a NAS as the share name changed) and it worked great. Hi everybody, I must do the change in the next week. I hope this will work at 4.8.10.0 I have one question if this succeed correctly, we will agree that emby server will keep all viewed movie by user ? Or we will lost this information ? It coud have an issue on statistic extension ? As my emby server is virtualized, I think I will copy the entire virtual machine in case of ^^ I will come back to you to say what is it Thanks a lot,
Luke 42243 Posted January 31, 2025 Posted January 31, 2025 59 minutes ago, remid12 said: Hi everybody, I must do the change in the next week. I hope this will work at 4.8.10.0 I have one question if this succeed correctly, we will agree that emby server will keep all viewed movie by user ? Or we will lost this information ? It coud have an issue on statistic extension ? As my emby server is virtualized, I think I will copy the entire virtual machine in case of ^^ I will come back to you to say what is it Thanks a lot, Hi I would think user data should mostly be preserved using this method.
DonMacaroni 55 Posted February 9, 2025 Posted February 9, 2025 On 12/13/2023 at 9:20 AM, DaveM77 said: For anyone who stumbles across it wondering if it still works - I followed this today for doing the same (I had to update a path for a NAS as the share name changed) and it worked great. Tried this and all metadata got still nuked Looks like editing XML's is not enough.
remid12 5 Posted February 11, 2025 Posted February 11, 2025 Thanks @Lukefor your answer. As my goal is to change the name of library which are on network from IP to hostname ( for example instead have \\192.168.1.1\FIlms modify by \\EmbyServer\Films ) I will make a copy on my complete virtual computer. In this way when I restart if it's not good, I will be able to come back to originial situation. I will try the procedure, and I will come back to you to say want I do, or must do to complete succefuly the operation. 1
