Radiant9 0 Posted October 4, 2019 Posted October 4, 2019 Hello, building collections within collections is no more working in the newer emby versions. Is their any solution to fix that ? Greets
Luke 42217 Posted October 4, 2019 Posted October 4, 2019 There are existing topics about this, which @@Happy2Play might be able to help locate. It's not available in the UI due to too many problems and troubleshooting. If you really want, you can hack a collection.xml file to add one collection into another. But we're not going to expose it in the UI until it is bulletproof and just works.
Detail4687 4 Posted October 11, 2019 Posted October 11, 2019 on trick is to select 2 or more collection, then with the three button at the top-right select "add to collection". Then, within the target collection remove the one you don't want.
